vernonlee Posted May 22, 2015 Author Posted May 22, 2015 Maybe a typo look at this carefully the extra space "ISO A0 " Yes. I notice it previously & have corrected it but it still render the same error. (COMMAND "-plot" "Y" "[b]\\[/b]PLOTSTN2[b]\[/b]hp500ps" "ISO A0" "m" "LANDSCAPE" "N" "E" "1:1" "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N" "Y" "Y") (COMMAND "-plot" "Y" "[b]\\\[/b]PLOTSTN2[b]\\[/b]hp500ps" "ISO A0" "m" "LANDSCAPE" "N" "E" "1:1" "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N" "Y" "Y") (COMMAND "-plot" "Y" "[b]\\\\[/b]PLOTSTN2[b]\\[/b]hp500ps" "ISO A0" "m" "LANDSCAPE" "N" "E" "1:1" "C" "Y" "RS485-URA A0 COLORED.ctb" "Y" "N" "N" "N" "Y" "Y") Same error (COMMAND "-plot" "Y" " Quote
BIGAL Posted June 6, 2015 Posted June 6, 2015 Run it short (COMMAND "-plot" "Y" "\\\\PLOTSTN2\\hp500ps") then try (COMMAND "-plot" "Y" "\\\\PLOTSTN2\\hp500ps" "ISO A0") till you find error Quote
nukecad Posted June 6, 2015 Posted June 6, 2015 Would this be a networked plotter? You can't call a networked plotter from a macro, you have to use a script or a lisp. The script in post #2 of this has always worked for me in the past with networked plotters: http://www.cadeverything.com/help/showthread.php/6523-Printing-1000-files Quote
vernonlee Posted June 8, 2015 Author Posted June 8, 2015 Run it short (COMMAND "-plot" "Y" "\\\\PLOTSTN2\\hp500ps") then try (COMMAND "-plot" "Y" "\\\\PLOTSTN2\\hp500ps" "ISO A0") till you find error Ok. U will try this if the script methods suggestion on script do not work for me. Quote
vernonlee Posted June 8, 2015 Author Posted June 8, 2015 Would this be a networked plotter? You can't call a networked plotter from a macro, you have to use a script or a lisp. The script in post #2 of this has always worked for me in the past with networked plotters: http://www.cadeverything.com/help/showthread.php/6523-Printing-1000-files Thanks. I will give it a try. Quote
vernonlee Posted June 10, 2015 Author Posted June 10, 2015 Would this be a networked plotter? You can't call a networked plotter from a macro, you have to use a script or a lisp. The script in post #2 of this has always worked for me in the past with networked plotters: http://www.cadeverything.com/help/showthread.php/6523-Printing-1000-files Thanks. Just tested it up to the point before printing so of I believe it should work. Finally Quote
