3dwannab
Select objects in current layer
3dwannab
(sssetfirst nil (ssget "_X" '((8 . "5"))))
will select objects in layer 5 no problem but when i incorporate
(getvar "CLAYER")
to make:
(sssetfirst nil (ssget "_X" '((8 . (getvar "CLAYER")))))
It comes back with error: ; error: bad SSGET list value
It's probably just a simple fix (heck, maybe even a standard command to do the same)
Thanks in advance.
Share this post
Link to post
3dwannab
mAC;633024]See if you can work out why from my tutorial The Apostrophe and the Quote Function ;)
Sorry, maybe having a slow day but I can't get that to work. Have tried which seems like the most logical solution:
(setq ss (getvar "CLAYER"))
(sssetfirst nil (ssget "_X" '((8 . (list ss)))))
from this example:
_$ (setq x 5)
5
_$ (list 1 2 3 4 x)
(1 2 3 4 5)
I'm learning maxscript also and find it much more user friendly to learn.
Share this post
Link to post
Lee Mac
Refer to the ssget example in this section - remember that any expression following a quote/apostrophe will not be evaluated.
Share this post
Link to post
3dwannab
Thanks. Maybe my brain isin't all there today but looking at your example didn't help. I still know you're the LISP master :)
I found this link here in the help: http://exchange.autodesk.com/autocad/enu/online-help/browse#WS73099cc142f4875516d84be10ebc87a53f-7a31.htm
I've came up with three variations which do the same thing :shock:
(setq lay_name (getvar "CLAYER"))
(setq ss1 (ssget "_X" (list (cons 8 lay_name))))
(command "pselect" "P" "")
(setq ss1 (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
(command "pselect" ss1 "")
Thanks for your help.
Share this post
Link to post
tombu
Glad you found a solution, but Lee's link explains the quote function as well as any I've seen. Do you understand now that the difference between using quote -vs- the list and cons functions is that any expression following a quote/apostrophe will not be evaluated?
Share this post
Link to post
3dwannab
I do to some degree it will sink in eventually. I don't know want has happened but NONE of the examples I had working are working now. Commandline is now saying "Unknown command "PSELECT". Press F1 for help." All those were working perfectly beforehand.
My lisp so far.
(defun c:SEL_LAYER_CURRENT ( / cmdecho )
   (setq  cmdecho (getvar 'cmdecho))
   (setvar 'cmdecho 0)
   ;;(princ (strcat "\n" (sslength ss1) " objects selected. "))
   ;;(print (sslength ss1))
   (setvar 'cmdecho cmdecho)
I also want to print the amount of selected objects after the command has finished but I having trouble joining up the text string and the amount of objects.
Share this post
Link to post
Tharwat
Eg.
(defun c:Test (/ s)
 (if (setq s (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
   (princ (strcat "\nNumber of Found objects : < " (itoa (sslength s)) " >"))
 (sssetfirst nil s)
Share this post
Link to post
3dwannab
Eg.
(defun c:Test (/ s)
 (sssetfirst nil s)
Excellent Tharwat. I understand fully what all that code does. (I thought I tried itoa to convet it to a string!!) Thanks very much. I think this simple routine will take over the LAYWALK command for me. BTW it could be useful of it allowed the user to have the dialog open. Anyway this is great. Here's the code.
;;---------------=={ 3DwannaB_Sel_Layer_Current.lsp }==-----------------;;
;;  Selects All Objects On Current Later                                ;;
;;  Author: 3DwannaB, Copyright © 2015                                  ;;
;;  Version 1.0    -    23-05-2015                                      ;;
;;  First Release. Lots of help from 'Lee Mac' Credit goes to 'Tharwat' ;;
;;  See http://bit.ly/1HzZrlM                                             ;;
(defun c:SEL_LAYER_CURRENT (/ s cmdecho )
   (setvar 'cmdecho 0)
   (sssetfirst nil s)
(princ
   (strcat
       "\n:: 3DwannaB_Sel_Layer_Current.lsp | Version 1.0 | by 3DwannaB  ::"
       "\n:: Type \"Sel_Layer_Current\" to Invoke                          ::"
;;                             End of File                              ;;
Share this post
Link to post
Tharwat
You are most welcome .
Can you tell me what is the need of the System Variable CMDECHO into the routine ?
Share this post
Link to post
3dwannab
I suppose it doesn't really have much use here. Force of habit putting it in there I suppose. Would it also be difficult to get this to search block tables to the current layer and select the block. Would be very useful for cleaning up drawings. I know I have the LAYTRANS command but sometimes manual is the only way sometimes.
Share this post
Link to post
Lee Mac
Thank you tombu :thumbsup:
Share this post
Link to post
3dwannab
Hi,
Why would this fail if the layers name is:
ConstructionArrayLine [DO NOT DELETE]
(defun c:QS_LAYER_CURRENT (/ ss_1 )
(if
	(setq ss_1 (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
	(princ (strcat "\nNumber of found objects : < " (itoa (sslength ss_1)) " >"))
(sssetfirst nil ss_1)
(command "._regenall")
Share this post
Link to post
ronjonp
It's because the name uses brackets. Try ConstructionArrayLine `[DO NOT DELETE`]
Share this post
Link to post
Lee Mac
You need to escape the wildcard operators present in the layer name (in this case, the square brackets "[" & "]").
For this, you can use my Escape Wildcards function:
(defun c:qs_layer_current ( / s )
   (if (setq s (ssget "_X" (list (cons 8 (LM:escapewildcards (getvar 'clayer))) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
       (princ (strcat "\nFound " (itoa (sslength s)) " object" (if (= 1 (sslength s)) "." "s.")))
       (princ "\nNo objects found.")
   (sssetfirst nil s)
Share this post
Link to post
3dwannab
I actually looked at your ssget examples Lee to see if there was anything about special characters. Maybe it was there but I missed it.
Thank you and thanks for your great functions.
Share this post
Link to post
tombu
Worked great, I added it to my modified SSX.lsp so it would work as well. After searching all my code for "(assoc 8" and found 186 occurrence(s) in 95 files I decided it's best not to ever use any wildcard operators in our layer names. It's worked for us so far.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
