ahazen
Batch hyperlinking based on attribute names in blocks
ahazen
I have hyperlinks to attach with names like 360-001.html or http://www.website.com/360-001. I was wondering if I could get help automating the hyperlinking process for these blocks. So block with attribute "001" would automatically be hyperlinked with http://www.website.com/360-001 when the command is run.
Share this post
Link to post
BIGAL
You can get at a blocks attribute value pretty easy using block name, tag name or pick a block and tag name, lots of example code here. In a lisp use -hyperlink and answer prompts.
(setq obj (car (entsel "Pick block")))
(foreach att (vlax-invoke (vlax-ename->vla-object obj) 'getattributes)
      (if (= "PROJ_NO" (strcase (vla-get-tagstring att))) ; change to your tag name
      (setq val  (vla-get-textstring att ))
      ) ; end if
Share this post
Link to post
Lee Mac
Please refer to your thread here.
Share this post
Link to post
ahazen
Thanks! RonJon helped me out. Learning from what he did now :D
Share this post
Link to post
