adelancy Posted August 7, 2015 Share Posted August 7, 2015 I'm working with a floor plan that was forwarded by a contractor. When I go to paper space in the layout tab, a big "S" appears in the middle of the floor plan but it is not there in the model space. How do I make the "S" disappear from my paper space layout? I'm using AutoCAD 2012 - the file I'm working with was created from a newer version that I had to "save down". Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 7, 2015 Share Posted August 7, 2015 Welcome to CADTutor. It sounds like the S was created in paperspace, not Modelspace. If you click on it to select it, you can likely learn a great deal about it from the Properties or Quick Properties. Report back to us if you are unable to select it, or if you are able to select it and need further assistance. Quote Link to comment Share on other sites More sharing options...
adelancy Posted August 7, 2015 Author Share Posted August 7, 2015 No, the "S" isn't in paperspace. I can't select it, only the viewport is selected. If I click inside of the viewport and it toggles to modelspace, then I can select the "S" - the entire floorplan is selected. I can open it in block editor but the "S" is not there, just as it's not there when I go to the model tab. But it is still there in the paperspace layout. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted August 7, 2015 Share Posted August 7, 2015 Sounds like the S is perhaps part of a linetype which the scale changes in paperspace, or an annotative text style? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 7, 2015 Share Posted August 7, 2015 (edited) Try using the NC (Nested Copy) command to create a copy of the S, and you will be able to get some information off the extracted copy. You will be able to figure out from the Properties of the copy, what sort of entity it is, whether or not it is annotative, text style, scale, layer, and such, which will help to determine how you should approach it. Edited August 7, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
adelancy Posted August 7, 2015 Author Share Posted August 7, 2015 I have found a resolution, though I have no idea about the why's and the how's of the resolution. I deleted the viewport from the paperspace layout tab, then created a new viewport and scaled it accordingly. The mysterious "S" did not appear in the new viewport. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 7, 2015 Share Posted August 7, 2015 Can you post the drawing? All we need is the S to be there and behaving as you indicate. Quote Link to comment Share on other sites More sharing options...
adelancy Posted August 7, 2015 Author Share Posted August 7, 2015 Well, I thought I had a resolution. I saved the drawing, opened it back up, and the "S" is back. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 7, 2015 Share Posted August 7, 2015 Have you tried the NESTED COPY approach? Quote Link to comment Share on other sites More sharing options...
adelancy Posted August 7, 2015 Author Share Posted August 7, 2015 I've got a resolution again, using the NESTED COPY approach. I had not been familiar with that command. I was able to click the properties of the copy and find the layer that it was on. I somehow missed this in my own search, but after turning that layer off within the viewport (and globally b/c I just don't need it), the big "S" disappeared. Thanks for the help! Much appreciated! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 7, 2015 Share Posted August 7, 2015 (edited) Excellent, glad that did it, happy to help. The first step in solving any problem, is recognizing that there is one, the second is identifying it. Out of curiosity, what was it? I like NESTED COPY, it comes in very handy when working with blocks. Edited August 7, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 7, 2015 Share Posted August 7, 2015 I'm betting it was an annotative scaling thing. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted August 9, 2015 Share Posted August 9, 2015 I'm betting it was an annotative scaling thing. That's what I said. I'm sure it was something like that. Quote Link to comment Share on other sites More sharing options...
