MLine keep fill after explode
Hello Community,
is there a way to keep the fill of a MLINE after I explode it? I'd like to have single LINES with a HATCH. Or is there a diffrent way to achieve this? I'd like to draw e.g. two lines with a solid hatch in between at once.
Thanks and kind regards
d1212
I use AutoCAD 2016
  • 2 weeks later...
A custom pline routine would be the way to go offset 2nd line then close ends, and join then hatch. Need a couple of rules is it central or a left/right offest as you draw. There should be something already out there, I think I have seen something about closing two plines.
