Separate/copy layer to other place by user pick point then sorting them..
Separate/copy layer to other place by user pick point then sorting them horizontal
below code not sorting horizontal.how to change the code, become horizontal (see image attached)
(defun c:test1 ( / _move d ss l lst ) (vl-load-com)
 (defun _move ( obj p q dist )
   (vla-move (setq obj (vla-copy obj)) (vlax-3D-point p) (vlax-3D-point q))
   (vla-move obj (vlax-3D-point '(0. 0. 0.)) (vlax-3D-point (list dist 0. 0.)))
 (if
   (and
     (ssget "_:L")
     (setq p1 (getpoint "\nBase Point: "))
     (setq p2 (getpoint "\nDesired Location: " p1))
     (setq p1 (trans p1 1 0) p2 (trans p2 1 0))
     (vlax-for obj (setq d 10. ss (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-acad-object))))
       (_move obj p1 p2
         (cond
           ( (cdr (assoc (setq l (vla-get-layer obj)) lst)) )
          ((cdr (assoc (vl-string-right-trim "D" l) lst)))
                ((cdr (assoc (strcat l "D") lst)))
           ( (setq lst (cons (cons l (setq d (- d 650.))) lst)) d )
     (vla-delete ss)
Link to post
