Rooster Posted July 14, 2016 Posted July 14, 2016 (edited) Using AutoCAD 2016 & 2017, I've been having a mystery block (_closedbank) and mystery layer (base) that keeps appearing in my template. This is not a block that I have ever created, and I've never named a block with any name like that. Same with the layer 'base'. If I open up my template, the layer is empty and the block is not present, so I am able to purge both and save. However, if I open up the template again (or use it as the base for any drawing) both these elements reappear until I purge again. After that, they're gone from my drawing. It's not a major problem, as I can ignore & purge, but I would like to know why?? Any suggestions/similar experiences? Edited July 14, 2016 by Rooster typo Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 It sounds like you are not saving the template properly. Are you doing a Save As and changing the file type to .dwt? Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 Okay, please post the template file. Next guess is that some sort of customization is loading them when you open a file. Do they reappear in every file? Quote
Rooster Posted July 14, 2016 Author Posted July 14, 2016 I just got rid of the layer. Found a block that had a rogue base point parameter to it. Still struggling with the block - just looked closer, and it's actually called _ClosedBlank (not bank). Searching Google I see other references to this name, but not tracked down what it is yet. I have purged my template & ensured that this block is not present - however, as soon as I start a new drawing it's in the list (albeit still with no occurrences in my drawing, so able to purge straight away)... Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 You are already doing that. The issue is it keeps coming back and it is hard to determine where it is coming from without a file or being there. Can you share the template just to verify that it is indeed staying purged until a file is created from it? And again, do they reappear in every file that you open? Quote
Rooster Posted July 14, 2016 Author Posted July 14, 2016 Template attached - thanks for taking an interest! (I've had to saveas in DWG filetype as it wouldn't let me upload DWT) Yes, the _ClosedBlank appears in every single new drawing begun using this template (ie. start new dwg using QNEW to open a file based on my template). Before doing anything else go to PURGE and under the BLOCKS section is _ClosedBlank X2016.dwg Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 I got that it happens with new drawings. I'm asking, if it happens to existing files as well. Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 My best guess is that it is contained in a block somewhere but I have no idea how to track it down. Quote
Rooster Posted July 14, 2016 Author Posted July 14, 2016 no, existing files are fine. also files that are subsequently created from this template - once the initial purge has happened they're fine too Quote
RobDraw Posted July 14, 2016 Posted July 14, 2016 I'm betting it is embedded in one of those blocks. There are ways to systematically track it down but I don't know any of them. Quote
Rooster Posted July 14, 2016 Author Posted July 14, 2016 thanks - i'll keep looking. it won't get the better of me! Quote
SLW210 Posted July 14, 2016 Posted July 14, 2016 Are you sure that is the template set to open as Qnew? Quote
ReMark Posted July 14, 2016 Posted July 14, 2016 Isn't _ClosedBlank the name for one of the arrowhead blocks that is a part of AutoCAD? I opened your template but did not see a layer called BASE listed. Quote
Dadgad Posted July 15, 2016 Posted July 15, 2016 (edited) Are you sure that is the template set to open as Qnew? I suggest that in order to confirm that it is you open OPTIONS, on the FILES tab, select TEMPLATES, click on the Default QNew option there and browse to be sure which is your current default QNEW template. Once you are sure which one it is, you can open the .dwt file, and purge it. The dwg file which is generated upon opening your Autocad, is not created from the specified QNEW default template. Sounds like that may be what is giving you the run around, that or as SLW implies, your default template is not the one you mean to, or think you are using. Edited July 15, 2016 by Dadgad Quote
Rooster Posted July 15, 2016 Author Posted July 15, 2016 Thanks for the replies... ReMark - I did eventually manage to get rid of the 'base' layer before uploading the template here. From Google searches I believe that you're right that _ClosedBlank refers to some sort of arrowhead/leader. I'll take a close look at any blocks that may contain these first. With regards to QNEW and opening the right template, yes this is definitely the correct one set up in the Options tab. Quote
ReMark Posted July 15, 2016 Posted July 15, 2016 If you look in the DimStyle dialog box on the Symbols and Arrows tab under the heading Arrowheads and click on the down pointing arrow for the first entry you will see that "Closed blank" is a listed arrowhead style that comes standard with AutoCAD. My advice would be to ignore it. In the scheme of things it matters not one iota. Quote
RobDraw Posted July 15, 2016 Posted July 15, 2016 In the scheme of things it matters not one iota. ... unless you are OCD about your files. I have a habit of getting hung up on these little things, especially in a template. Quote
