hello ,,
i just need small help here .
i know its my first time to be active since long time but if please help its very urgent .
i have 3d surface mad by surveyor . i need to generate cross sections every 2.5 meters ! .
i can do it by using the commands ( point with apparent intersection and then connect with 3d poly line then loft command .. but it will take me more that 2-3 days to finish and there are more coming ! :(:(
all i need is lisp or any thing can help me to finish this issue . i read it can be done on civil 3d but i have zero background about this software .
its urgent and must be done within 2 days =\
thanks ! .. i'll attach the cad file hoping some one help me ! .
3d surface.dwg
Edited by Romiui
  • Replies 20
  • Romiui
    12
  • Stefan BMR
    4
  • BIGAL
    3
  • SLW210
    1
thank you for replay , but it doesn't help ,
all i need is not to keep clicking point command and apparent intersection every time then connect with 3d poly line .. i need ready lisp can take the job of doing the intersection direct .
thanks !
Hi Romiui
I've made something similar for 3DFaces.
Can you convert this to Lisp:
- get start p1=(x1 y1 z1) and end p2=(x2 y2 z2) of each segment from each 3dPoly
- for a given y0 position of the cutting line, if y0 is between y1 and y2, you can get the apparent intersection point p0=(x0 y0 z0) like this:
x0 = [x1*(y0-y2)+x2*(y1-y0)]/(y1-y2)
p0 = (x0 y0)
z0 = [z2*(dist p1 p0)+z1*(dist p0 p2)]/[(dist p1 p0)+(dist p0 p2)]
p0 = (x0 y0 z0)
- put each such p0 point in a list, sort it ascending by x and build the section as a 3dpoly.
@Stefan BMR Thank You body.
i'am not sure if i can make it as lisp =P .. i'll try lisp editor .
thank .
if u can please help me to convert this drawing to solid then i can slice it ? I've done 50% of the 3dpoly and this cross sections should go to the meeting evening .. i'am really stuck ! ..
i hope i have this civil 3d experience to do ..
thanks again !
i just attached the drawing in-case u can help or any body els ! ..
Draw the cutting lines and I'll do the sections for you.
oh ! .. thanks !! 5 min i'll send the drawing =)
i know its looks Too Much . but if will take u time . all i need is solid surface so i can slice it with slice tool and i can do the job .
thank you and I do highly appreciate your efforts .
Screened Stock Pile.dwg
done. Sent you a PM.
EDIT: Nope, you cant receive PM till you have some specific number of post.
yes, it's done. But I have some issues and I wanted to discuss with you in private. Unfortunately, you cannot receive private messages right now.
Romiui I think you missed the point of my post, there is free software out there that will do contours, cross sections and Long sections. A quick google should have found them.
eg EZYSURF
Maybe have a look at the FREE CadTools. A Donation includes even more functionality.
thanks for the tool .. i tried it out but i have no idea to how really use it as will !. i read the help file but no luck .
thanks .
A quick comment you have plines not 3dfaces, they are joined to look like a TIN, Triangular Irregular Network or DTM Digital Terrain Model. As posted it would take about 2-3 minutes to make cross sections from your data using CIV3D or one of the free packages.
I dont know which Tool you refer to but you make an alignment then walk down that alignment making cross sections at generally a fixed spacing. So draw a line from mid of horizontal lines top to bottom, this is your alignment, you may have to explode the plines, in CIV3D 3dlines are a valid input option not plines.
thanks for reply ! i used the cadtools application and still confusing for me . and for the civil 3d i dont have the software and i never use it before .
any way i'll attach u my other 3d surface or what ever called poly . any if u please make the cross section for me i'll appreciate that .
its really hard to me to make it and am stuck with other 3d surfaces now almost finish 80% so this one left which attached in this reply .
if u helped thank, if u cant also thanks for ur efforts to help out =) .
Regards.
Romiui .
edit : i've done it .. thanks ..
if i got something els i'll ask for help !
Mixed STOCK PILE 31 08 16 (00000003).dwg
Edited by Romiui
