Grrr Posted September 21, 2016 Posted September 21, 2016 Grrr - Okay that lisp in #16 worked fine , in fact it's better than the original in that I don't have to select only polylines or only lines at a time. The real question though is why am I now able to run a lisp? I assume you added code which overcame whichever error I was getting as I still get no value when I run the original. Thats great to hear! And to elaborate the answer from my previous post: In AutoLISP there are extension functions, prefixed with vla-/vlax-/vlr-, which are part of the Visual Lisp (extension of AutoLISP), to load them (vl-load-com) must be used. The previous codes I posted, require this Visual Lisp - but for some reason they don't work for you, even after you use (vl-load-com). The last code I posted - doesn't require these VLISP extensions, so its a temporarily solution for you. I have no idea what might be the (real) problem, so look-up into ReMark's suggestions. And consider to hire someone like Lee Mac or Tharwat. Quote
MisterJingles Posted September 22, 2016 Author Posted September 22, 2016 Thanks Grrr, I will look deeper into the cause at a later stage. For now the work-around will do what I need. Quote
