Copy text into same place but in different layer
Grr using Lee's parse CSv you would make a list of the words seperated by a space then compare each word with other language make a new string and replace. Keep the word list as a file on its own 2 bits of info original other per line. Just use a load
; mini lsp
(setq lstfrench (list
word1 word1french
Wesley need a sample data say 5 words each language.
Making use of defuns would simplify the repetitive nature of the problem.
After reading this (and knewing the unimaginable amount of his subfunctions) I think that he should consider about creating a new extension for AutoLISP, called LMLISP.
  • Replies 23
  • Wesley_Amsterdam
    8
  • Grrr
    6
  • BIGAL
    5
  • Lee Mac
    2
Posted Images
I will give it a shot!
I do get an error while installing the .exe file.
Already contacted the support from coins.
Thnx for the tip!
I will let you know if it works oke or not.
It works fine for the tags.
Thnx Lee!
