MattJcooper
Help with changing a single number (attribute) in multiple blocks
MattJcooper
Hi - New to auto cad & need help :cry: I'll explain as best i can.
Version:AutoCAD Mechanical 2012.
I have a number of CAD blocks i need to change an attribute in each of the blocks multiple times. The attribute DEVNAME - Varies* over multiple blocks.
I need to change the number used in the attributes eg:
Block 1 attribute DEVNAME = RR1
Block 2 attribute DEVNAME = LR1
Block 2 attribute DEVNAME = AR1
I would like to change the 1 in all the attributes to a 2 without having to manually change each attribute name individually.
The result I'm after would be:
Block 1 attribute DEVNAME = RR2
Block 2 attribute DEVNAME = LR2
Block 2 attribute DEVNAME = AR2
I have hundreds to change hopefully there is an easy way. Thanks in advance any help i receive.
Share this post
Link to post
BIGAL
Using FIND will change block attributes find RR1 replace RR2
2nd option Lee-mac has a global attribute editor.
Share this post
Link to post
