urdaddy
U-Turn modelling
urdaddy
Does anyone has any idea how to model this kind of U-turn which is basically end of the road in the same time and it's curved at the end?
qwtwhczvh
Share this post
Link to post
ReMark
Are you saying Civil 3D doesn't do cul-de-sacs?
BTW...Civil 3D questions are best posted in the AutoCAD Vertical Products forum. This forum is for plain AutoCAD which does not possess the same feature set as Civil 3D.
Share this post
Link to post
urdaddy
Don't know mate. It's difficult for me because I have to keep the profile which goes through the centerline of the road before the U-turn. Have completly no idea how to even start it.
Guess so subassemblies won't be usefuel as the endpoint is behind the section between edge of the U-turn and centerline. Another thing is that, at the edge of Uturn I have to prepare a ditch.
o6ofhc3ir
Share this post
Link to post
ReMark
Ahhhhhh....the Internet. How did we live without it?
I don't use Civil 3D but I do know how to do a search. Follow this link. Maybe one or more of the search results will get you started on your way until a fourm member with actual experience in the program and knowledge of which you seek is able to assist you.
https://www.google.com/search?q=civil+3d+culvert+design&ie=utf-8&oe=utf-8#q=civil+3d+cul-de-sac+design
Share this post
Link to post
BIGAL
You need to make an alignment along the kerb starting before the end TP and finishing after the opposite TP this way you get the correct grades at the TP points. Remark is right culdesac or here in AUS a court Bowl.
Easiest way for first timers is design along back of kerb and go right around the court bowl. You change the road shape at the TP from a full road to a kerb. This is just one method.
Like Remark pretty sure there are some tutorials out there its a common problem. Hard to explain quickly in a post like this.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
