samifox Posted June 13, 2017 Posted June 13, 2017 hi i need to export my dwg into sketchup, but all the unsupported object should be in sketchup so what are my options? for example text, how can i turn it into a primitive geometry? Thanks S Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 Explode text? Sent from my MOBIX M6 using Tapatalk Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 Explode it? Explode text? Sent from my MOBIX M6 using Tapatalk Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 Really? It is possible to explode text object! Sent from my MOBIX M6 using Tapatalk Quote
ReMark Posted June 13, 2017 Posted June 13, 2017 Yes, if you have Express Tools installed. Express Tools > Text > Explode Text. Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 Thanx Sent from my MOBIX M6 using Tapatalk Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 hi my local language fonts are not encoded properly, the explode in the express tools vanish my text object. is there any other trick to turn text into a polyline? Quote
ReMark Posted June 13, 2017 Posted June 13, 2017 I doubt they have vanished. Did you do a zoom > extents after exploding the text objects? Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 yaaa sometimes it vanishes sometimes its not . its all about the styles i remember how i plot it to plt, and than resave it as a dxf, this action kills all objects can be any more friendly way? Quote
ReMark Posted June 13, 2017 Posted June 13, 2017 Not that I am familiar with. Maybe someone else will have a suggestion. The rare times I have used the Explode Text command and the text had gone off screen it only turned out to be a case of doing a zoom > extents to find it. I have never had text totally vanish for good. Quote
samifox Posted June 13, 2017 Author Posted June 13, 2017 i think the express tool does wmfin and wmfout that's why things goes wrong with the position after fact Quote
f700es Posted June 14, 2017 Posted June 14, 2017 So you want your text in the DWG file to come over to SU, right? Why, what are you trying to accomplish? Quote
samifox Posted June 14, 2017 Author Posted June 14, 2017 So you want your text in the DWG file to come over to SU, right? Why, what are you trying to accomplish? i have servy with lots of textual information i like to translate to a sketchup model Quote
f700es Posted June 14, 2017 Posted June 14, 2017 AutoCAD text does not do well in SU. If it was me it just re-do it in SU. SU is not meant for lots of annotations. That's why they made LayOut. Quote
samifox Posted June 14, 2017 Author Posted June 14, 2017 one way is to do the elevation in autocad but i cant handle 3d there, the other way is to plot to PLT and than convert to DXF. this way everithing is pure dot geometry. really not 2017 but that all the info i got Quote
f700es Posted June 14, 2017 Posted June 14, 2017 I am not following your work flow, sorry. Are you making a model or are you making construction plans (elevations and such) from a SU file? Walk me through what you are doing and wanting to do. Quote
samifox Posted June 14, 2017 Author Posted June 14, 2017 in sketchup im creating an architectural design where i translate all the survey and site plan's elevation data to 3D , and than i export cuts and elevation drawings to autocad. in this way all the model geometry is done with sketchup and all annotation made in autocad. Quote
f700es Posted June 14, 2017 Posted June 14, 2017 OK that makes sense but why do you want to take text from AC into SU? It sounded like you want to do drawing annotation in SU. Quote
