tive29 Posted June 29, 2017 Author Posted June 29, 2017 Here is two code examples of finding title blocks it needs the two to be combined into one that suits your needs. http://www.cadtutor.net/forum/showthread.php?100977-pagesetup-with-lisp-with-several-layout-A3-A0.-A1 Thanks but the title block is just a rectangle polyline in the size of A4, A3 & A2. So I am not sure how the lisp can help. Quote
FranknBeans Posted June 29, 2017 Posted June 29, 2017 Sorry I am a little confused now what you want the lisp to do. You want no intervention from the user but you want the lisp to create a folder, is the location not the same every time? Your first post asked to save in D:\pdf\ or documents so I thought the location must exist already. BIGAL has posted code that will create a folder automatically if that is what you need. Quote
FranknBeans Posted June 29, 2017 Posted June 29, 2017 does this work for you? (BIGAL's code with a small typo fix) (defun c:pp ( / dwgpre pdfname ) (setq dwgpre (strcat (getvar "dwgprefix") "pdf\\")) (if (= (vl-file-directory-p dwgpre) nil) (vl-mkdir dwgpre) ) (setq pdfname (strcat dwgpre [color=red](getvar "dwgname")[/color] "-" (getvar "ctab") ".pdf" )) (command "tilemode" "0") (command "-plot" "y" "" "Dwg To PDF.pc3" "ISO expand A4 (210.00 x 297.00 MM)" "M" "P" "N" "W" "" "" "1:1" "C" "Y" "Myplotstyle.ctb" "Y" "N" "N" "N" pdfname "N" "Y") ) Quote
tive29 Posted June 30, 2017 Author Posted June 30, 2017 Thanks FranknBeans. It works now. does this work for you?(BIGAL's code with a small typo fix) (defun c:pp ( / dwgpre pdfname ) (setq dwgpre (strcat (getvar "dwgprefix") "pdf\\")) (if (= (vl-file-directory-p dwgpre) nil) (vl-mkdir dwgpre) ) (setq pdfname (strcat dwgpre [color=red](getvar "dwgname")[/color] "-" (getvar "ctab") ".pdf" )) (command "tilemode" "0") (command "-plot" "y" "" "Dwg To PDF.pc3" "ISO expand A4 (210.00 x 297.00 MM)" "M" "P" "N" "W" "" "" "1:1" "C" "Y" "Myplotstyle.ctb" "Y" "N" "N" "N" pdfname "N" "Y") ) Quote
FranknBeans Posted June 30, 2017 Posted June 30, 2017 ha! all credit to BIGAL, it seems he knew what you wanted minutes after your first post Glad you got there in the end though Quote
tive29 Posted June 30, 2017 Author Posted June 30, 2017 ha! all credit to BIGAL, it seems he knew what you wanted minutes after your first post Glad you got there in the end though Thanks for putting it together as I would not have been able to do that. Quote
