ElCidCampeador
Exclude from macro a specific area of drawing
Is it possible to exclude from a vba macro for Autocad a specific region? For example, apply this macro not to all modelspace but only to a part (which has not lines as boundaries but defined only by position reference x,y in autocad). Thanks
Share this post
Link to post
I'd go this way:
- check every drawing entity to be handled by the macro against the intersections it has with the "allowed" region perimeter (which is likely to be a polyline)
- if there are no intersections then let the macro operate on that drawing entity
- if there is any intersection then skip that drawing element
as a side note for handling intersections, I guess you're working on a 2D model so be sure all elements and the region perimeter has the same "elevation" property
As an alternative you could use SelectionSet object and select only elements within a certain boundary.
and then have macro operate on every element (if any) of that selection set (just iterate over selection set items)
Share this post
Link to post
Like RICVBA look at the help for ssget "W" "F" "CP" this is lisp but the same in VBA
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
