Saeed_AGHJANI Posted September 15, 2017 Share Posted September 15, 2017 hello my frieand , how can i repeat Arc (Center , start , end ) Command without select From Draw tab? i have problem with this Command when i want to use Continuous, everytime i Should select again from Draw Pannel of Home Tab for use again! ( i want to use this like move command , for ex : select move & use that , Click Enter and use again from Move ) but in the Arc Command when u Click enter , autocad select Arc whit 3 Points! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 15, 2017 Share Posted September 15, 2017 If you hit C after starting the Arc command it goes to the Center, Start, End. You need to watch the Commandline. Command: ARC Specify start point of arc or [Center]: c Specify center point of arc: Specify start point of arc: Specify end point of arc or [Angle/chord Length]: Quote Link to comment Share on other sites More sharing options...
Saeed_AGHJANI Posted September 15, 2017 Author Share Posted September 15, 2017 I know how it draw! but i want to draw again after use this command with ENTER click! i want select this command again , without select arc with 3 point! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 15, 2017 Share Posted September 15, 2017 Takes a fraction of a second to hit Enter, C. You asked for a method to do this without using the draw tab and I gave you that. If that's not what you want, you need to give a better explanation. Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted September 16, 2017 Share Posted September 16, 2017 keep things simple. repeat a command with enter and look at command line area for options. im proud to say i only use ribbons when i am ready to annotate. if all else fails properties panel Quote Link to comment Share on other sites More sharing options...
