Halb10
Saveas Directory using attribute Value
Halb10
Hi,
is there a way to save my drawing with its name in a directory by using a Attribute value.
Example:
Drawingname: test.dwg
blockname: TitleBlock
Attribute: SF:WE
Attribute-Value: test2
And it should save the drawing in:
C:drawing/test drawing/(attribute-value)/...
but it should be in a dialogbox, so i can choose the specific subfolder
the direcotry up to the attribute-value is fix.
Share this post
Link to post
Halb10
(defun c:FOO (/ LM:GetAttributeValue ss attValue)
(setvar "filedia" 0)
 (defun LM:GetAttributeValue (blk tag / val enx)
   (while
     (and
       (null val)
       (= "ATTRIB"
          (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))
      (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
        (setq val (cdr (assoc 1 enx)))
 (if (and (setq ss (ssget "X" '((0 . "INSERT") (2 . "TitleBlock") (66 . 1))))
          (setq attValue (LM:GetAttributeValue (ssname ss 0) "SF:WE"))
     (command "_saveas" "_2007" (getfiled "Speichern" (strcat "C:\\drawing\\test drawing\\(*****)" (vl-filename-base (getvar "dwgname"))) "dwg" 1)
     ;(prompt (strcat "\n[Attribute Value] : " attValue))
(setvar "filedia" 1)
got this Code. But I can't get it to work. (*****) there should be attValue.
Share this post
Link to post
rlx
A couple of things , firstly , I would place the getfiled outside the command function because all error checking has to be done before you run this. Secondly , are you certain this folder always exists? Also you would need an additional "\\" between (****) and the (vl-filename-base (getvar "dwgname")) and another at the end of this same expression.
 (getfiled "testje" "d:\\temp\\lisp" "dwg" 0)
is not the same as
 (getfiled "testje" "d:\\temp\\lisp\\" "dwg" 0)
(with the \\ at the end
gr. Rlx
Share this post
Link to post
Halb10
Ok, so something like this
(command "_saveas" "2007")
(getfiled "Speichern" (strcat C:\\drawing\\test drawing\\(attValue)\\" (vl-filename-base (getvar "dwgname"))) "dwg" 0)
Yes, the folder exists.
Is it possible with this kind of code to do this? Because I don't know how to get the Attribute Value in the Directory.
Share this post
Link to post
rlx
untested :
(defun c:FOO (/ LM:GetAttributeValue ss attValue fol fn)
 (vl-load-com)(setvar "filedia" 0)
   (while (and (null val) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk))))))))
      (if (= (strcase tag) (strcase (cdr (assoc 2 enx)))) (setq val (cdr (assoc 1 enx))))))
   (vl-file-directory-p (setq fol (strcat "C:\\drawing\\test drawing\\" attValue)))
   (setq fn (getfiled "Speichern" (strcat fol "\\" (vl-filename-base (getvar "dwgname"))) "dwg" 1))
     (command "_saveas" "_2007" fn)
Share this post
Link to post
Halb10
That works fine. Exactly what I needed.
Thank you rlx
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
