kwayteow Posted April 28, 2019 Author Posted April 28, 2019 4 hours ago, ReMark said: One trick would be to give it a thickness then convert to a solid. i have tried used thicken command, sculpt, convtosolid but nothing happened it's not working, is the problem came from shape object? googling but got nothing until now Quote
BIGAL Posted April 29, 2019 Posted April 29, 2019 My suggestion was like cad64 but using radials so can make more surface points, may need to convert to points along the pline created and create a 3d surface but it will be facets not true smooth. Thinking out side the square look at boat hull software. Thinking a bit more do a big dome 3d solid with fixed arc then vertical edge buy subtracting plan shape do a fillet on vertical edge, Need some time to play. Quote
