toxicsquall
Get Z coordenate from a point or 3Dpolyline
toxicsquall
I'm having a problem getting a Z coordinate from a point or a object, like a 3dPolyline.
I need to put a text in front of it. I have this one, but it only gets the X and Y coordinates and I just need the Z coordinate.
Quote
(defun C:incoord (/ pc)
 (setq pc (getpoint "\nClick on the point: "))
 (while pc
    (##InsTextCoord pc)
    (setq pc (getpoint "\nNext Point [Or <Enter> to end]: "))
(defun ##InsTextCoord (ponto / px py)
    (setq px (car ponto))
    (setq py (cadr ponto))
    (command ".text" ponto "" "" (strcat "X= " (rtos px) ", Y= " (rtos py)))
(princ "\n INCOORD to start")
Share this post
Link to post
Emmanuel Delay
  (while pc
    (##InsTextCoord pc)
(defun ##InsTextCoord (ponto / px py pz)
    (setq pz (caddr ponto))
    (command ".text" ponto "" "" (strcat "X= " (rtos px) ", Y= " (rtos py) ", Z= " (rtos pz) ))
Share this post
Link to post
dlanorh
You could just
(defun c:incoord (/ pc)
  (while (setq pc (getpoint "\nClick on the point or Enter to End : "))
    (command ".text" pc "" "" (strcat "Z = " (rtos (caddr pc))))
    ;(command ".text" pc "" "" (strcat "X = " (rtos (car pc)) ",Y = " (rtos (cadr pc)) ",Z = " (rtos (caddr pc))))
(princ "\nType incoord to start")
If you want X,Y & Z comment out the first (command ".text" ....) and uncomment the second (command ".text" ....)
Share this post
Link to post
toxicsquall
THANK YOU SO MUCH!!!!
The last one worked exactly as i wish for.
Share this post
Link to post
