  • Replies 28
  • pmadhwal7
    15
  • dlanorh
    11
  • BIGAL
    2
  • tombu
    1
Rather vague request.
You want the difference in Elevation between two selected text objects?
Like tombu ??
(while (setq t1  (vlax-ename->vla-object (car (entsel "pick text object"))))
(setq t2  (vlax-ename->vla-object (car (entsel "pick text object"))))
(setq z1 (nth 2  (vlax-safearray->list (vlax-variant-value (vla-get-insertionpoint t1)))))
(setq z2 (nth 2  (vlax-safearray->list (vlax-variant-value (vla-get-insertionpoint t2)))))
(alert (strcat "The difference is " (rtos (abs (- z1 z2)) 2 2)))
I thinke he wants to interpolate the elevation base on the text values of the two text items. Would still need to know what to use as the base points or if there is a node, and whether this is a random infill etc
yes sir u r right....
I can open your drawing, but it is not very informative. Can your repost with a before and after so I can see what you are trying to do. I have 3 or 4 lisps which do something similar to what you require, and this would help me adapt one for your needs.
Also is this a random infill, or infill every "?" distance
Ignore the infill request at the end of the day you will end up with a TIN answer irrespective of the number of points. Every 3 original points will make a plane. All you would be doing is add points to this plane. If you contour the points, then convert to lines with a z add end points delete lines infill done. If you want it more surface wise you need more original points. Maybe ucs 3 points then just add point will test.
OR
Do you just want points between two points given how many 4 10 20  ?
pmadhwal7 you really have to explain more.
Edited by BIGAL
OR
Sir,
i just want to points and its not fixed sometime it was more the 3-4 sometime only 1 point
15 minutes ago, pmadhwal7 said:
Sir,
Try the attached.
This will insert a level ramdomly around the mid point of the two levels selected (0.4 -> 0.6) of the distance
infill_levels2.lsp
48 minutes ago, dlanorh said:
Try the attached.
lisp was working but levels is different if i draw one line in between two text and move any text to that line then
The lisp is designed to create a new text entity between two existing text entities using their insertion points or text alignment points as the as the "line". It assumes said text entities have the correct levels (as text) within them. The text level displayed is an interpolation of the difference in the (text) levels at that point.
Sir check this,
OK, a misunderstanding on my part. I assumed from your drawing that the text's textstring was the level. I will amend accordingly.
OK. Try the attached. I'm not sure if this is exactly what you want but it's a bit closer. This will put a text at the MID point between the two selected texts and display its level.
infill_levels2.lsp
yes sir...
very close sir but in my dwg i have some code like 'BW , WL, etc. and the given lisp working only on elevation's also i din't want to elevation on particular i want  random distance elevation..
Then please try to explain in detail, what you want. A drawing with before and after examples would be fantastic. If you are inserting text that has a code, what should the code for the new text  item be?
Edited by dlanorh
spelling
