dilan
Function write-line. Align lines.
dilan
Hello everyone!
I can’t understand how can I align lines when I write to a file using a function write-line.
For example, here is the program:
(defun write_example ( / pt lst fl_name count )
(while
  (setq pt (getpoint "\nClik ->>"))
  (setq lst (cons pt lst))
) ;_while
(if (and
     lst
    (setq fl_name (acet-ui-getfile "--< Save as... >--" (getvar "DWGPREFIX") "txt" "" 1))
(setq count 1)
(setq fl(open fl_name "w"))
(write-line "         №              X              Y               Z" fl)
(foreach itm lst
  (write-line (strcat "         " (rtos count 2 0)
                      "              " (rtos (car itm))
					  "              " (rtos (cadr itm))
					  "              " (rtos (caddr itm))) fl)
(setq count (+ count 1))
); foreach
(close fl)
); end progn
); end if
); end defun
In the end, this is what I get in the file:
         №              X              Y               Z
         1              1129.795              2571.649              0.000
         2              1125.115              2576.517              0.000
         3              1126.632              2583.535              0.000
         4              1133.969              2587.707              0.000
         5              1145.100              2590.615              0.000
         6              1143.899              2583.408              0.000
         7              1140.547              2578.477              0.000
         8              1135.993              2577.655              0.000
         9              1126.696              2584.609              0.000
         10              1125.241              2590.173              0.000
         11              1127.012              2596.053              0.000
         12              1136.689              2591.184              0.000
         13              1147.946              2582.460              0.000
         14              1148.389              2575.189              0.000
         15              1146.239              2572.028              0.000
         16              1140.800              2573.103              0.000
         17              1136.309              2579.678              0.000
         18              1136.309              2585.747              0.000
But I want to get like this:
         №              X                     Y                     Z
Tell me please. How can I do that?
thank
Share this post
Link to post
BIGAL
Try using say tabs (strcat "x" (chr xx) "y" (chr xx) etc I will have to look up what a tab is. need my ascii table. found it 9 (chr 9)
Edited by BIGAL
Share this post
Link to post
rlx
Other way than \t could be
(defun write_example (/ pt lst fl_name count l)
  (while (setq pt (getpoint "\nClik ->>")) (setq lst (cons pt lst)))
  (if (and lst (setq fl_name (acet-ui-getfile "--< Save as... >--" (getvar "DWGPREFIX") "txt" "" 1)))
      (setq count 1 l 15 fl (open fl_name "w"))
      (write-line (strcat (fus "No" l)(fus "X" l)(fus "Y" l)(fus "Z" l)) fl)
      (foreach itm lst
        (write-line (strcat (fus (itoa count) l) (fus (rtos (car itm)) l)
                            (fus (rtos (cadr itm)) l) (fus (rtos (caddr itm)) l)) fl)
      (close fl)
; fill up string
(defun fus (s i) (while (> i (strlen s))(setq s (strcat s " "))) s)
Share this post
Link to post
dilan
      (foreach itm lst
      (close fl)
; fill up string
Thanks, it's cool, but I get it like that:
No             X              Y              Z
1              992.774        979.172        0.000
2              993.442        980.264        0.000
3              996.053        984.089        0.000
4              996.479        986.518        0.000
5              997.268        989.735        0.000
6              995.446        992.467        0.000
7              993.077        994.532        0.000
8              992.409        997.264        0.000
9              993.381        1000.360       0.000
10             995.446        1004.913       0.000
11             993.503        1007.706       0.000
12             989.190        1007.706       0.000
13             986.275        1005.581       0.000
14             979.412        1005.703       0.000
15             979.473        1009.467       0.000
16             977.408        1011.592       0.000
17             973.885        1012.381       0.000
18             967.690        1010.742       0.000
19             963.621        1006.249       0.000
20             960.038        1009.527       0.000
And I need like this:
 No             X              Y              Z
I need the number to shift to the left
Now the number is shifting to the right
Edited by dilan
Share this post
Link to post
rlx
(defun write_example (/ pt lst fl fl_name count l)
      (write-line (strcat (flus "No" 6)(flus "" 9)(fus "X" l)(fus "Y" l)(fus "Z" l)) fl)
      (foreach itm lst
        (write-line (strcat (flus (itoa count) 6) (flus "" 9) (fus (rtos (car itm)) l)
      (close fl)
; fill up string
; fill up string
(defun flus (s i) (while (> i (strlen s))(setq s (strcat " " s))) s)
Share this post
Link to post
dilan
      (foreach itm lst
      (close fl)
; fill up string
; fill up string
Thank you very much rlx
Share this post
Link to post
rlx
you're welcome. Note that Bigal's suggestion to use tabs ("\t") is working too for the x/y/z part of your table if all number are roughly the same length , so you would only need to right align your counter and the rest could be done with tabs. Doubt in real life you would be able to measure the difference in speed but theoretically tabs should be a little faster.
:beer:
Share this post
Link to post
dilan
:beer:
thanks again
Share this post
Link to post
BIGAL
The less than 10 is pretty common this is another simple example of padding.
Rlx nice idea "\t"
(if (< (car dwgnum) 10.0)
      (setq newstr2 (strcat dwgname "-D0"  (rtos sheetnum 2 0)))
      (setq newstr2 (strcat dwgname "-D"  (rtos sheetnum 2 0)))
Edited by BIGAL
Share this post
Link to post
dilan
Rlx nice idea "\t"
thanks BIGAL
Share this post
Link to post
