jim78b Posted August 14, 2019 Share Posted August 14, 2019 i use isometric drawing in autocad , and i draw a line length 20mm autocad draw a line length 20 but if i use a lisp isoblocks.lsp https://autocadtips1.com/2012/03/21/autolisp-easily-create-isometric-blocks/ the lengt hof the lines change? why?is another isometric projection? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 14, 2019 Share Posted August 14, 2019 An isometric drawing is by definition a projection, but it's orthographic. In other words everything is projected, but it's all projected at the same ratio. In a perspective view, the projection angle varies based on distance from the camera. From what I can tell, this LISP routine automatically projects horizontal lines to 30 degrees. If you want a 20mm line in the block, you'll need to draw it at some length that becomes 20 at 30 degrees. It's a trigonometry problem, but I forgot everything I learned about trig in the 80s. Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 14, 2019 Author Share Posted August 14, 2019 1 hour ago, CyberAngel said: An isometric drawing is by definition a projection, but it's orthographic. In other words everything is projected, but it's all projected at the same ratio. In a perspective view, the projection angle varies based on distance from the camera. From what I can tell, this LISP routine automatically projects horizontal lines to 30 degrees. If you want a 20mm line in the block, you'll need to draw it at some length that becomes 20 at 30 degrees. It's a trigonometry problem, but I forgot everything I learned about trig in the 80s. Yes .i can not edit this lisp ...i think was projected on the same ratio .if you draw a linee in .autocad in isomode the length is the same you enter the Value in ortho mode . Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 15, 2019 Author Share Posted August 15, 2019 Can you edit the lisp please ? Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 15, 2019 Author Share Posted August 15, 2019 i use isometric drawing in autocad , and i draw a line length 20mm autocad draw a line length 20 but if i use a lisp isoblocks.lsp https://autocadtips1.com/2012/03/21/autolisp-easily-create-isometric-blocks/ the lengt of the lines change...i want the same length As 2d drawing. There is someone who van modify the lisp ? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 15, 2019 Share Posted August 15, 2019 I have merged your threads, please post the same question only once in the most appropriate forum. Quote Link to comment Share on other sites More sharing options...
jim78b Posted August 15, 2019 Author Share Posted August 15, 2019 Thanks Quote Link to comment Share on other sites More sharing options...
lrm Posted August 15, 2019 Share Posted August 15, 2019 In the precise definition of an isometric drawing lines (object edges) that are parallel to one of the principal axes (x, y, or z) are drawn true length at an angle of 8 or - 30° or vertically. Thus a 20mm long edge in the x direction of the 3D model would be drawn at an angle of 30°. An isometric projection on the other hand is the result of making a parallel projection (as opposed to a perspective projection) of the 3D shape to a plane. The plane for an isometric projection is perpendicular to any of the diagonals of a cube. Each of the principal axes of the 3D object form an angle of about 35.2644° (asin(1/sqrt(3)) with the projection plane. An object rotated to an isometric orientation yields geometry that is scaled by about 82% (0.81649…). This is equal to the cosine of 35.2644°. Thus the 20mm line would be about 16.33mm long in the projection (20 * cosine(35.2644) ) . Bottom line? Forget the math and scale the isometric projection to yield an isometric drawing by scaling it up by this factor or 1.224744… (the inverse of 0.81649). Quote Link to comment Share on other sites More sharing options...
