juicyorange
Assigning and Custom Drawing Property to a variable
juicyorange
Hey guys,
I'm looking to assign a custom property to a variable and I have no idea how to do it.
In the 0 custom prop I put a testvalue
Here is the code I have so far:
(vl-load-com)
(defun c:test (/)
  (setq acadObject (vlax-get-Acad-Object)
	acadDocument (vla-get-Activedocument acadObject)
	;; set existing custom properties to dProps
	dProps (vlax-get-property acadDocument 'Summaryinfo)
  ;; get the value at the specifed index in the dProps and assign it to location
  (vla-GetCustomByIndex dProps 0 "IMPCSVLOC" location)
I can't find any documentation on the "vla-GetCustomByIndex" so I don't really know how to use tbh.
I've attached a file that has the custom property setup.
All insight and help is appreciated.
Thanks,
JT
testfile.dwg
Edited by juicyorange
tags
Share this post
Link to post
juicyorange
5 minutes ago, tombu said:
Try:
(setq  si (vla-Get-SummaryInfo (vla-Get-ActiveDocument (vlax-Get-Acad-Object))))
(vla-GetCustomByKey si  "IMPCSVLOC" 'pval)
(princ pval)
See: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/update-custom-drawing-properties/m-p/3641908#M306757
also shows how to set to a new value or add a new custom info.
there we go, exactly what I was looking for.
thanks!
Share this post
Link to post
juicyorange
I seem to have hit another snag.
What I'm trying to do is define a default location for a getfile command I have and when I use that string it doesn't use the default location I've set.
Here's the code:
(vl-load-com)
(defun c:test (/)
  (vla-GetCustomByKey dProps  "IMPCSVLOC" 'pval)
  (setq fileloc (princ pval))
    (setq	csvfile	(getfiled "Select CSV File"
			  fileloc
			  "csv"
			  10
I have also attached the updated test file.
testfile.dwg
Share this post
Link to post
tombu
Here's the code:
(vl-load-com)
(defun c:test (/)
			  pval
			  "csv"
			  10
Simply changing "C:\Users" to "C:\Users\ got it to work, but I removed the fileloc stuff as it didn't seem to serve a purpose.
Share this post
Link to post
juicyorange
EDIT
I read your code, i'll give it a shot
Share this post
Link to post
juicyorange
I don't know what I was doing before, but it is working for me now.
Thanks!
Share this post
Link to post
