amir0914
Polyline Dimension
amir0914
Hi all,  I need a lisp to add dimension to closed polyline, and is it possible to set all the dimension line only into the polyline?
Thanks in advanced.
dim.dwg
Share this post
Link to post
hanhphuc
many examples just search ->  pdim by Marko
suppress arrow head looks tidy..
Share this post
Link to post
amir0914
Thank you, is there a way to find out if a point is inside or outside of a closed polyline?
Share this post
Link to post
BIGAL
This code is from an old post here I have removed the color problem.
; code by Alanjt
(defun _isPointInside (polygon point / temp test)
 (if (vlax-curve-isClosed polygon)
   (progn (setq test (eq (length (vlax-invoke
                                   (setq temp (vlax-ename->vla-object
                                                (entmakex (list '(0 . "XLINE")
        '(100 . "AcDbEntity")
        '(100 . "AcDbXline")
        (cons 10 point)
        (cons 11 (trans '(1. 0. 0.) polygon 0))
                                   'IntersectWith
                                   (vlax-ename->vla-object polygon)
                                   acExtendNone
                         6
          (vla-delete temp)
          test
(_isPointInside (car (entsel "\nselect pline"))(getpoint "\nPick a point")) returns T
Share this post
Link to post
amir0914
; code by Alanjt
        (cons 10 point)
                                   'IntersectWith
                                   acExtendNone
                         6
          (vla-delete temp)
          test
Thank you BIGAL, that was very helpful, I have another question :
I'm trying to run circle command for each item in list, but it's not working :(3 is radius)
lst = ((x1 y1 z1) (x2 y2 z3) (x3 y3 z3) ..)
(mapcar 'Circle (list lst) 3)
Share this post
Link to post
BIGAL
Try this
(repeat (setq x (length lst))
(setq pt (nth (setq x (- x 1)) lst))
(command "circle" pt 3.0)
Share this post
Link to post
amir0914
2 hours ago, BIGAL said:
Try this
I knew it before, but I would write that with mapcar or lambda or apply. like this function for midpoint:
(defun mid (p1 p2)
  (mapcar (function (lambda (a1 a2) (/ (+ a1 a2) 2.0))) p1 p2) ;| #lambda |;
Edited by amir0914
Share this post
Link to post
BIGAL
Thinking a bit more its easily solved if you use is pline clockwise or anti, you can use Reveres to do just that on the pline. Then can use vertices as internal angle is always +90. Need though arc to be done differently. I have a check anti but I need a better one.
Your other question (foreach pt lst (Command "circle" pt 3))
Edited by BIGAL
Share this post
Link to post
amir0914
Thanks for your reply, my first issue has been resolved by draw a ray and find out the point if is inside or outside of the polyline. now, only problem I have that is the dimension text string has overlap with other texts in polyline. do have a way for this problem?
Share this post
Link to post
