amb2301
Lisp required to Align zig zag placed attributes
amb2301
Hi Friends,
       i got some task to align zig zag attributes to proper way as shown in screenshot.
also i have attached the sample dwg file for the same, could someone please provide me lisp to do this task,
it would be a great help for me.
Thanks in Advance.
sample_dwg.dwg
Share this post
Link to post
Tharwat
This should work unless you have the insert point of your attributed blocks far from the attribute definition.
(defun c:test (/ int sel 1pt 2pt alg ent ins cls)
  (and (princ "\nSelect Attributed blocks to align to line : ")
       (setq int -1
             sel (ssget "_:L" '((0 . "INSERT") (66 . 1)))
       (setq 1pt (getpoint "\nSpecify base point of line : "))
       (setq 2pt (getpoint "\nSpecify next point of line : " 1pt))
       (setq
         alg (entmakex (list '(0 . "LINE") (cons 10 1pt) (cons 11 2pt)))
       (while (setq int (1+ int)
                    ent (ssname sel int)
         (and (setq ins (cdr (assoc 10 (entget ent)))
                    cls (vlax-curve-getclosestpointto alg ins)
              (vlax-invoke (vlax-ename->vla-object ent) 'Move ins cls)
  (and alg (entdel alg))
) (vl-load-com)
  • Thanks 2
Share this post
Link to post
rlx
Brilliant  as always Tharwat 👍
  • Thanks 1
Share this post
Link to post
amb2301
Thank you so much Sir, it worked perfectly.
Really you saved my day Sir.
Share this post
Link to post
Tharwat
Thank you rlx, that's to kind of you to say. :)
You're welcome anytime. :)
Share this post
Link to post
Jonathan Handojo
Tharwat, one check is to make sure that the current layer is unlocked so entdel works. It's one of the most annoying checks to miss...
Plus, I believe it's better if you supply the "extend infinitely" argument to the vlax-curve-getclosestpointto function, just my opinion so that you can just supply the two points closer to each other.
Nonetheless, everything else is great!
Edited by Jonathan Handojo
Share this post
Link to post
Tharwat
Thanks Jonathan for your comments.
Definitely I agree with you but my codes were to help the OP to automate their work and it was not a commercial program to account for every eventuality that the user might think of or encounter, so its simple as that.
Share this post
Link to post
