Import and convert a surface point cloud into multiple dwg
Hello everyone,
I am facing a difficulty, I have more than 300 point cloud files already converted to RCP (RECAP) and I need to import the following routine,
1. Open a new drawing
2. Atach the dense cloud .RCP
3. Select the dense cloud and Convert it to Civil 3D
4. Adjust on the surface and adjust the interpolation distance limit, mesh between points, to 0.5m
6. Save and close the file and start the cycle again.
My difficulty is that I was unable to create a script or locate a LISP that performs the conversion of the point cloud via command without having to interact with the user.
I would be very grateful if someone can help me.
Best Regards,
hello
Attached an example drawing and  RCP (RECAP) file
What does -pointcloudattach do and -CREATESURFACEFROMPOINTCLOUD
Hi @BIGAL
I try this -createsurfacefrompointcloud but the C3D open a popup to user choose the options.
Now I can create sequencial dwg using SDI=1 by script.
