prodromosm Posted December 2, 2021 Share Posted December 2, 2021 Hi .I am using this code to a multi-page pdf at once. I want two changes in this code 1) I want to select the insert point of the pdf and not start all the time from the 0,0 2) When iinsert all the pages the need to press esc to stop the code Can ane one fix this code?? Thanks ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq n 1) (setq pt '(0.0 0.0 0.0));;prompt for insertion point here (while (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (polar pt 0.0 8.5)) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 2, 2021 Share Posted December 2, 2021 if you look through it, question 1 is answered in the comments. Use the getpoint command instead of coordinates, google is your friend here. You could change the line to (setq pt (getpoint "Insertion Point")) 1 Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 2, 2021 Author Share Posted December 2, 2021 Hi Steven P. Thanks for the replay. I did the change in the code and the first question solved. When i insert all the pages then need to press esc to stop the code. Why ? CAn any one fix it? Thanks ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq n 1) ;(setq pt '(0.0 0.0 0.0));;prompt for insertion point here (setq pt (getpoint "Insertion Point")) (while (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (polar pt 0.0 8.5)) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 2, 2021 Share Posted December 2, 2021 It will be the while loop not finishing as it should, not sure why - but I haven't looked for you, someone might see something obvious though Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 2, 2021 Author Share Posted December 2, 2021 Thank you Steven P for your time. If some one find something please help. Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 2, 2021 Share Posted December 2, 2021 (edited) Google more pretty sure it was Lee-mac you can get how many pages in a pdf. So do a repeat not a while. number of pdf pages autocad lisp I found the answer as the 1st result and went 2 links down and found the number of pages in a pdf.lsp Edited December 2, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 2, 2021 Author Share Posted December 2, 2021 Hi BIGAL .Sorry but i can not understand where is the error !!! Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 2, 2021 Share Posted December 2, 2021 This (while keeps looping as it never gets a condition that says exit, a (repeat 8 would do for 8 pages, I found the how many pages in a pdf just google. 1 Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 2, 2021 Author Share Posted December 2, 2021 I find this but how to use it ? Is the Lee Mac code http://www.theswamp.org/index.php?PHPSESSID=vo6pn2p86vt6mh6ab9khjfd3p7&topic=39001.msg441632#msg441632 (defun _PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) (vl-load-com) (princ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 3, 2021 Share Posted December 3, 2021 You need to run the defun it returns "pag" so (repeat pag Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 1 hour ago, prodromosm said: I find this but how to use it ? Is the Lee Mac code Read the top part of the lisp. you have to feed it a link to the pdf. Since your fn variable has that just feed it that. (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq n 1) (setq pt (getpoint "Insertion Point")) (while to (setq fn (getfiled "Select PDF File" "" "pdf" 8)) ;might want to make this an if statment (setq n 1) (setq pt (getpoint "Insertion Point")) (repeat (_PDFPageCount fn) Quote Link to comment Share on other sites More sharing options...
StevJ Posted December 3, 2021 Share Posted December 3, 2021 Neat programs. Is there a way to move the insertion point of the next PDF page the width of the previously inserted page rather than a fixed distance? Landscape pages will overlap portrait pages and makes quite a mess. I changed the point distance from 8.5 to 17.25, and that fixes overlaps, but leaves large gaps between adjacent portrait pages and makes for a really wide and difficult to manage drawing with a 40-page PDF. Steve Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 (edited) @StevJ Their might be a quicker/better way. Using bounding box on the last entity in the drawing aka the PDF page that was just inserted to find out its width. This should do what you asked for. remember to also load the _PDFPageCount function. (defun c:atall (/ fn n pt LL UR objwid) (setq fn (getfiled "Select PDF File" "" "pdf" 8) n 1 pt (getpoint "Insertion Point") ) (repeat (_PDFPageCount fn) (command "-pdfattach" fn (itoa n) "_non" pt 1 0) (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) objwid (- (car UR) (car LL)) pt (polar LL 0 (+ objwid 1)) ;1 is the spacing you want between pages. n (1+ n) ) ) (command) (princ) ) Edited December 3, 2021 by mhupp added notes Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 3, 2021 Author Share Posted December 3, 2021 Hi mhupp. Thanks for the repay. I use the code and gives me this error !!!! Insertion Point; error: bad argument type: fixnump: nil here is the code i use ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (defun _PDFPageCount ( filename / fob fso mat reg res str ) (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) (vl-load-com) (princ) (defun c:atall (/ fn n pt LL UR objwid) (setq fn (getfiled "Select PDF File" "" "pdf" 8) n 1 pt (getpoint "Insertion Point") ) (repeat (_PDFPageCount fn) (command "-pdfattach" fn (itoa n) "_non" pt 1 0) (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) objwid (- (car UR) (car LL)) pt (polar LL 0 (+ objwid 1)) ;1 is the spacing you want between pages. n (1+ n) ) ) (command) (princ) ) Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 Copied what you posted and everything works on this end. Sounds like the error is happening when trying to insert the pdf. Finding out a lot of things work in Bricscad but not so well in Autocad. (itoa n) is converting a integer into a string. Maybe Autocad needs a integer only? (defun c:atall (/ fn n pt LL UR objwid) (setq fn (getfiled "Select PDF File" "" "pdf" 8) n 1 ) (setvar 'cmdecho 0) (if (setq pt (getpoint "Insertion Point")) (repeat (_PDFPageCount fn) (command "-pdfattach" fn n "_non" pt 1 0) (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) objwid (- (car UR) (car LL)) pt (polar LL 0 (+ objwid 1)) ;1 is the spacing you want between pages. n (1+ n) ) ) (prompt "\nAn Insertion Point is Needed") ) (command) (setvar 'cmdecho 1) (princ) ) Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 3, 2021 Author Share Posted December 3, 2021 Is not working. Not insert the pdf ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (defun _PDFPageCount ( filename / fob fso mat reg res str ) (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) (vl-load-com) (princ) (defun c:atall (/ fn n pt LL UR objwid) (setq fn (getfiled "Select PDF File" "" "pdf" 8) n 1 ) (setvar 'cmdecho 0) (if (setq pt (getpoint "Insertion Point")) (repeat (_PDFPageCount fn) (command "-pdfattach" fn n "_non" pt 1 0) (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minpt 'maxpt) (setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt) objwid (- (car UR) (car LL)) pt (polar LL 0 (+ objwid 1)) ;1 is the spacing you want between pages. n (1+ n) ) ) (prompt "\nAn Insertion Point is Needed") ) (command) (setvar 'cmdecho 1) (princ) ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 This worked for me in AutoCAD, some subtle differences from what you had (vl-load-com) (princ) (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq pagecount (PDFPageCount fn)) (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount ;; (while (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (polar pt 0.0 8.5)) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 3, 2021 Author Share Posted December 3, 2021 I use autocad 2022 and gives me this this error with your code Insertion Point; error: bad argument type: fixnump: nil Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 Not sure what part would cause that, it could be pagecount or could be pt, try commenting out the "(repeat pagecount" and the ")" the line after the "(setq pt (polar... "line If that doesn't work maybe change (setq pt (list (+ (car pt) 8.5) (cadr pt) (caddr pt))) instead of (setq pt (polar pt 0.0 8.5)) give a clue where the problem might be Quote Link to comment Share on other sites More sharing options...
prodromosm Posted December 3, 2021 Author Share Posted December 3, 2021 No. The same error. Quote Link to comment Share on other sites More sharing options...
