LISP to swap layers between objects
Caracolalbino
 Share
Hi, I'm kind of new to the forum, and I was looking for a routine that allows me to select one object and swap its layer with another objects' current one. Is it something that has been done? So far, I haven't found any built-in commands that do this, but I just might haven't searched thoroughly enough. Anyhow, thanks in advance!
Its easy enough to do but are we talking about one layer or multiple layers? if its multiple layers what layer goes where?
Sorry you said object I was thinking blocks.
;; SWITCH LAYERS BETWEEN OBJECTS
(defun C:SwapLayer (/ OA OB LA LB)
  (setq OA (car (entsel "\nSelect first object: "))
        LA (cdr  (assoc 8 (setq OA (entget OA))))
        OB (car (entsel "\nSelect second object: "))
        LB (cdr  (assoc 8 (setq OB (entget OB))))
  (if (eq LA LB)
    (prompt "\nBoth Entities are on same layer")
      (entmod (subst (cons 8 LB) (assoc 8 OA) OA))
      (entmod (subst (cons 8 LA) (assoc 8 OB) OB))
Edited by mhupp
  • Thanks 1
Wonderful, works like a charm! I really need to learn how to write lisp routines, what would you say would be the best way for someone to get started on the language/syntax?
https://www.afralisp.net/ is nice with simple step by step instructions.
https://www.cadtutor.net/tutorials/autolisp/quick-start.php  also good start but one page.
Coming to the forums regularly to see how people problem solve.
look for answer from people with high scores. there are multiple ways to code things in lisp. usually it comes down to performance (what runs the fastest)
but depending on user preference or other factors one type of code might win out over a faster code.
Reading over the functions to understand how to use them.
https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-4CEE5072-8817-4920-8A2D-7060F5E16547
Welcome and hope to see you around.
  • Like 4
Get a copy of Notepad++ a text editor has functions built in that helps when writing lisp's. A lot of us use it.
  • Like 2
 Share
