LISP Function to Get Layer On Off, Lock, Freeze state and restore them later
MAzri
I want to add another layer to my routine to allow saving of layer state for On/off, Lock, Freeze, and restore them back after routine.
I got the locked layer part but i could not understand this awesome crazy simple routine by Kent1Copper from Autodesk Forum
(defun GLL (/ lay); = Get Locked Layers
  (while (setq lay (tblnext "layer" (not lay)))
    (if (= (logand (cdr (assoc 70 lay)) 4) 4); locked
      (setq LockedLayers (strcat (cond (LockedLayers) ("")) (cdr (assoc 2 lay)) ","))
    ); if
  ); while
); defun
(defun UAL (); = Unlock All Layers
  (command "_.layer" "_unlock" "*" "")
); defun
(defun RLL () ; = Relock [formerly] Locked Layers
  (command "_.layer" "_lock" LockedLayers "")
); defun
Basically, I do not understand this part of code below, where and how it capture the lock/unlock layer state and how i can capture the on/off & freeze layer state
    ); if
  ); while
Many thanks in advance.
(while (setq lay (tblnext "layer" (not lay))) ;Process each layer in drawing
  (if (= (logand (cdr (assoc 70 lay)) 4) 4)   ;if layer is locked true
    (setq LockedLayers (strcat (cond (LockedLayers) ("")) (cdr (assoc 2 lay)) ",")) ;if true add layer name to end of string with ,
  ); if
); while
Its using dxf code to look at the layers and find what state they are in. 70 is used for frozen locked and a few others I didn't realize but makes sense.
lockedlayers would look something like
"0,Layer1,Layer2,Layer4, "
So RLL
(command "_.layer" "_lock" "0,Layer1,Layer2,Layer4, " "")
-Edit
maybe someone can explain to mean why he is using logand wouldn't this work just the same
(if (= (cdr (assoc 70 lay)) 4)
Edited by mhupp
  ); if
); while
So RLL
-Edit
So this is called dxf code. I need to study further on this. Thanks for the explanation.
On 24/12/2022 at 05:49, BIGAL said:
Ask him at Forums/autodesk.com/
Thanks. I guess I better to ask him there.
ps: i notice the link i made on Kent1Copper name is broken and link back to this thread. Here is the actual page on this
