wiebe Posted March 25, 2023 Share Posted March 25, 2023 (edited) Lable: (layer LG1, LG2, LG3) Line, Layer, count Current LSP VoorstelLSP TEST.dwg test.lsp Edited March 25, 2023 by wiebe Quote Link to comment Share on other sites More sharing options...
devitg Posted March 25, 2023 Share Posted March 25, 2023 @wiebe as you set all numbers insertion points [ 1 to 11] at the line , I did the same to the L1 L2 and so on. As to get the L1 et all by ssget "F" dxf 10 and dxf 11 from each line , if not there will be a hard way to do such ssget to get the LN. Or show me how do you put such LN at each line. Seem to be they where put at a equal distance from the each line dxf 10 . Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2023 Share Posted March 25, 2023 (edited) It looks like a 2 step process label the lines by layer, they may be mixed up in drawn order L1, L4, L2, L3. Then get the lengths etc has been done many times, there is a post at moment floating around that does what you want the missing step which if I get time will be to put a linetype in the table, will find. The other gotcha for this is if a line is drawn opposite way the label may be upside down and on right side not left side. For me I would use a ssget "F" option selecting over all the lines near left side so label always go that side. Answer Devitg questions why I have a hunt. Edited March 27, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
devitg Posted March 25, 2023 Share Posted March 25, 2023 2 minutes ago, BIGAL said: Answer Debitg questions why I have a hunt @BIGAL I found the this F ssget do not select the text (foreach ent ent@lay-lst (setq ent-10 (cdr (assoc 10 (entget ent)))) (setq ent-11 (cdr (assoc 11 (entget ent)))) (setq LN (ssname ( ssget "F" (list ent-11 ent-10) '( ( 0 . "text")))0)) (setq ln$ (cdr (assoc 1 (entget ln)))) (setq ln$-list ( cons ln$ ln$-list)) ) Given ENT@lay-list hold all lines at the same layer but with differents LX Because the fence do not get any text Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2023 Share Posted March 25, 2023 Link for other post may be useful. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-polyline-length-total-by-layer-in-table/td-p/11229892 Devitg understand but thought it would be better to label lines as part of the program. Quote Link to comment Share on other sites More sharing options...
devitg Posted March 25, 2023 Share Posted March 25, 2023 1 minute ago, BIGAL said: Devitg understand but thought it would be better to label lines as part of the program. @BIGAL That is what the OP lisp do at the before LISP (setq ent (nth 0 lst)) (foreach ent lst (setq lenlst (cons (vla-get-length (vlax-ename->vla-object (cadr ent))) lenlst)) (entmake (list (cons 0 "TEXT") (cons 10 (car ent)) (cons 40 250) (cons 1 (itoa c)) ) ) (setq c (1- c)) ) But it name each line from 1 to 11 , that is why I ask to OP to show how it named each line with Lx and Ly Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2023 Share Posted March 25, 2023 Need to add a layer check before writing text may be get a Selection list (( layer entity) ( layer entity) ( layer entity) ..... Sort on layer then label each line starting at a user number etc then step 2 is do table. A sample 1st step then walk through the list of entities. (prompt "Type F when asked for selection ") (setq ss (ssget '((0 . "LINE")))) (setq lst '()) (repeat (setq x (sslength ss)) (setq ent (entget (ssname ss (setq x (1- x))))) (setq layer (cdr (assoc 8 ent))) (setq entity (cdr (assoc -1 ent))) (setq lst (cons (list layer entity) lst)) ) (setq lst (vl-sort lst '(lambda (J K) (< (car J)(car K))))) 1 Quote Link to comment Share on other sites More sharing options...
devitg Posted March 26, 2023 Share Posted March 26, 2023 (edited) @BIGAL It is what I have Until I can not get the Ln from each line at each layer ;;******************************************************************************************************* (DEFUN REMOVE-DUPS (LISTE / RETLISTE) ;_ 01 (FOREACH ITEM LISTE (IF (NOT (MEMBER ITEM RETLISTE)) (SETQ RETLISTE (CONS ITEM RETLISTE)) ) ) (REVERSE RETLISTE) ) ;;******************************************************************************************************* (defun C:table-qty-lay-length (/ ss poly ent lst side lenlst pt objtable index c) (vl-load-com) (setq lst ()) (if (setq SS (ssget '((0 . "line")(8 . "LG1,LG2,LG3,LG*")))) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq ent (entget poly)) (setq lst (cons (list (cdr (assoc 10 ent)) (cdr (assoc -1 ent))) lst)) ;build list with point and entity name ) ) (setq ent (nth 0 lst)) (setq lay-lst ()) (foreach ent lst (setq lay (cdr (assoc 8 (entget (cadr ent))))) (setq lay-lst (cons lay lay-lst)) ) (setq uniq-lay (vl-sort (REMOVE-DUPS lay-lst) '<)) (setq lay (nth 0 uniq-lay)) (setq dat-list ()) (foreach lay uniq-lay (setq lay-ss (ssget "_X" (list (cons 0 "line") ( cons 8 lay)))) (setq ent@lay-lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex lay-SS)))) (setq ent (nth 0 ent@lay-lst)) (foreach ent ent@lay-lst (setq ent-10 (cdr (assoc 10 (entget ent)))) (setq ent-11 (cdr (assoc 11 (entget ent)))) (setq LN (ssname ( ssget "F" (list ent-11 ent-10) '( ( 0 . "text")))0)) (setq ln$ (cdr (assoc 1 (entget ln)))) (setq ln$-list ( cons ln$ ln$-list)) ) Edited March 26, 2023 by devitg add lisp Quote Link to comment Share on other sites More sharing options...
Tsuky Posted March 27, 2023 Share Posted March 27, 2023 Try with your lisp modified (defun C:test ( / ss poly ent lst c n obj el tmp lenlst pt objtable index) (vl-load-com) (if (setq SS (ssget '((0 . "LINE")(8 . "LG1,LG2,LG3")))) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq ent (entget poly)) (setq lst (cons (list (cdr (assoc 10 ent)) (cdr (assoc -1 ent))) lst)) ) ) (setq c 0 n 0) (foreach ent lst (setq obj (vlax-ename->vla-object (cadr ent)) el (list (vla-get-length obj) (vla-get-layer obj)) ) (if (member el (mapcar 'car lenlst)) (setq tmp (assoc (car (member el (mapcar 'car lenlst))) lenlst) lenlst (subst (cons el (cons (1+ (cadr tmp)) (cddr tmp))) tmp lenlst) ) (setq lenlst (cons (cons el (cons (1+ c) (setq n (1+ n)))) lenlst)) ) (entmake (list (cons 0 "TEXT") (cons 10 (car ent)) (cons 50 (angle (vlax-get obj 'startpoint) (vlax-get obj 'endpoint))) (cons 40 250) (cons 1 (strcat "L" (itoa (cddr (assoc el lenlst))))) ) ) ) (setq pt (getpoint "\nSelect point insertion table: ") objtable (vla-AddTable (vla-get-modelspace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-3d-Point pt) (+ 2 (length lenlst)) 4 60 270) index 1 ) (vla-settext objtable 0 0 "HELLO") (vla-SetCellTextHeight objtable 0 0 200) (vla-SetCellAlignment objtable 0 0 acMiddleCenter) (vla-setcolumnwidth objtable 0 500) (vla-setcolumnwidth objtable 1 1000) (vla-setcolumnwidth objtable 2 1000) (vla-setcolumnwidth objtable 3 1000) (vla-settext objtable 1 0 "NR.") (vla-SetCellTextHeight objtable 1 0 200) (vla-SetCellAlignment objtable 1 0 acMiddleCenter) (vla-settext objtable 1 1 "Length") (vla-SetCellTextHeight objtable 1 1 200) (vla-SetCellAlignment objtable 1 1 acMiddleCenter) (vla-settext objtable 1 2 "Layer") (vla-SetCellTextHeight objtable 1 2 200) (vla-SetCellAlignment objtable 1 2 acMiddleCenter) (vla-settext objtable 1 3 "Count") (vla-SetCellTextHeight objtable 1 3 200) (vla-SetCellAlignment objtable 1 3 acMiddleCenter) (foreach elem (reverse lenlst) (vla-SetText objtable (setq index (1+ index)) 0 (strcat "L" (itoa (cddr elem)))) (vla-SetCellTextHeight objtable index 0 200) (vla-SetCellAlignment objtable index 0 acMiddleCenter) (vla-SetText objtable index 1 (rtos (caar elem) 2 0)) (vla-SetCellTextHeight objtable index 1 200) (vla-SetCellAlignment objtable index 1 acMiddleCenter) (vla-SetText objtable index 2 (cadar elem)) (vla-SetCellTextHeight objtable index 2 200) (vla-SetCellAlignment objtable index 2 acMiddleCenter) (vla-SetText objtable index 3 (cadr elem)) (vla-SetCellTextHeight objtable index 3 200) (vla-SetCellAlignment objtable index 3 acMiddleCenter) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 27, 2023 Share Posted March 27, 2023 If more than 3 or less than (8 . "LG*") Quote Link to comment Share on other sites More sharing options...
Tsuky Posted March 27, 2023 Share Posted March 27, 2023 Quote If more than 3 or less than (8 . "LG*") I prefer (8 . "LG#") # -> # (pound) : Matches any single numeric digit. Quote Link to comment Share on other sites More sharing options...
wiebe Posted March 28, 2023 Author Share Posted March 28, 2023 Thanks for your cooperation (Tsuky/BIGAL) 1 more little question. how can I have the length sizes rounded to 30 or 80 in the table example: line length 1850 becomes 1880 L1 4202 --> 4230 L2 4202 --> 4230 L3 1952 --> 1980 L4 1952 --> 1980 L5 1952 --> 1980 Quote Link to comment Share on other sites More sharing options...
Tsuky Posted March 28, 2023 Share Posted March 28, 2023 Quote 1 more little question. how can I have the length sizes rounded to 30 or 80 in the table example: line length 1850 becomes 1880 L1 4202 --> 4230 L2 4202 --> 4230 L3 1952 --> 1980 L4 1952 --> 1980 L5 1952 --> 1980 Perhaps! Add this function at my lisp (defun round_number (xr n / ) (* (fix (atof (rtos (* xr n) 2 0))) (/ 1.0 n)) ) And change the line el (list (vla-get-length obj) (vla-get-layer obj)) To this el (list (round_number (+ (vla-get-length obj) 30) 0.1) (vla-get-layer obj)) Quote Link to comment Share on other sites More sharing options...
wiebe Posted March 29, 2023 Author Share Posted March 29, 2023 Tsuky, code does not give the desired result: line length 2867 - rounded code 2900 - wish outcome 2880 line length 3193 - rounded code 3220 - wish outcome 3230 etc. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 29, 2023 Share Posted March 29, 2023 (edited) The rounding will need a less than 30 for the last 2 digits then do similar for less than 100 need to think about it in a cond. 1224 divide 100 = 12.24 - fix = .24 less than 0.30 so it is changed to (0.30 + fix ) * 100 = 1230 Edited March 29, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
Tsuky Posted March 30, 2023 Share Posted March 30, 2023 Sorry, but your term: Quote how can I have the length sizes rounded to 30 or 80 in the table Misled me, this term would have been more accurate: Quote how can i have the length sizes in the range at 30 or 80 in the table. BIGAL is right in his reasoning. Here is the corresponding code (to be checked anyway; tested summarily) (defun range_number (x / ) (cond ((and (<= (- x (* 100 (fix (* 0.01 (fix x))))) 30) (not (> (- x (* 100 (fix (* 0.01 (fix x))))) 80)) ) (+ (* 100 (fix (* 0.01 (fix x)))) 30) ) (T (if (< (+ (* 100 (fix (* 0.01 (fix x)))) 80) x) (+ (* 100 (fix (* 0.01 (fix x)))) 130) (+ (* 100 (fix (* 0.01 (fix x)))) 80) ) ) ) ) (defun C:test ( / ss poly ent lst c n obj el tmp lenlst pt objtable index) (vl-load-com) (if (setq SS (ssget '((0 . "LINE")(8 . "LG#")))) (foreach poly (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq ent (entget poly)) (setq lst (cons (list (cdr (assoc 10 ent)) (cdr (assoc -1 ent))) lst)) ) ) (setq c 0 n 0) (foreach ent lst (setq obj (vlax-ename->vla-object (cadr ent)) el (list (range_number (vla-get-length obj)) (vla-get-layer obj)) ) (if (member el (mapcar 'car lenlst)) (setq tmp (assoc (car (member el (mapcar 'car lenlst))) lenlst) lenlst (subst (cons el (cons (1+ (cadr tmp)) (cddr tmp))) tmp lenlst) ) (setq lenlst (cons (cons el (cons (1+ c) (setq n (1+ n)))) lenlst)) ) (entmake (list (cons 0 "TEXT") (cons 10 (car ent)) (cons 50 (angle (vlax-get obj 'startpoint) (vlax-get obj 'endpoint))) (cons 40 250) (cons 1 (strcat "L" (itoa (cddr (assoc el lenlst))))) ) ) ) (setq pt (getpoint "\nSelect point insertion table: ") objtable (vla-AddTable (vla-get-modelspace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-3d-Point pt) (+ 2 (length lenlst)) 4 60 270) index 1 ) (vla-settext objtable 0 0 "HELLO") (vla-SetCellTextHeight objtable 0 0 200) (vla-SetCellAlignment objtable 0 0 acMiddleCenter) (vla-setcolumnwidth objtable 0 500) (vla-setcolumnwidth objtable 1 1000) (vla-setcolumnwidth objtable 2 1000) (vla-setcolumnwidth objtable 3 1000) (vla-settext objtable 1 0 "NR.") (vla-SetCellTextHeight objtable 1 0 200) (vla-SetCellAlignment objtable 1 0 acMiddleCenter) (vla-settext objtable 1 1 "Length") (vla-SetCellTextHeight objtable 1 1 200) (vla-SetCellAlignment objtable 1 1 acMiddleCenter) (vla-settext objtable 1 2 "Layer") (vla-SetCellTextHeight objtable 1 2 200) (vla-SetCellAlignment objtable 1 2 acMiddleCenter) (vla-settext objtable 1 3 "Count") (vla-SetCellTextHeight objtable 1 3 200) (vla-SetCellAlignment objtable 1 3 acMiddleCenter) (foreach elem (reverse lenlst) (vla-SetText objtable (setq index (1+ index)) 0 (strcat "L" (itoa (cddr elem)))) (vla-SetCellTextHeight objtable index 0 200) (vla-SetCellAlignment objtable index 0 acMiddleCenter) (vla-SetText objtable index 1 (rtos (caar elem) 2 0)) (vla-SetCellTextHeight objtable index 1 200) (vla-SetCellAlignment objtable index 1 acMiddleCenter) (vla-SetText objtable index 2 (cadar elem)) (vla-SetCellTextHeight objtable index 2 200) (vla-SetCellAlignment objtable index 2 acMiddleCenter) (vla-SetText objtable index 3 (cadr elem)) (vla-SetCellTextHeight objtable index 3 200) (vla-SetCellAlignment objtable index 3 acMiddleCenter) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
wiebe Posted April 1, 2023 Author Share Posted April 1, 2023 it works Thanks for your cooperation top Quote Link to comment Share on other sites More sharing options...
