Ciupanezul21 Posted September 21, 2023 Posted September 21, 2023 Good day, ladies and gentlemen I am a design engineer at a furniture factory and I have been working in autocad for about 7 years and the work has become quite difficult, many tasks in a short time and I saw that there are autolips automations and I was wondering if you could help me with an autolips for Auto quotes Dimensions to optimize my production time. I will show you in a few pictures how I would like this Autolips. I would be very grateful. More details * annotation Dimensions must be in steps * the measured diameter should be in letters And generating a text to extract the quantity and value of these holes near the part. DOOR 600.dwg Quote
BIGAL Posted September 21, 2023 Posted September 21, 2023 (edited) I would look at the front end I have a 2 column getvals but could do a 3 column version these are Library code so can be used in any software. You would pick a corner eg LL lower left, then enter in the dcl 3 values the X Y & Alpha. Oh yeah 1st go would be just enter overall size and the radius values A= 4 So custom dcls may be easier with more than one enter as a sequence. Something like this. Could do with a simpler getreal but if make one mistake have to do all again. Its going to take some time to do as a number of steps required. You may have to pay for this type of custom program. There are many of us here who can help. Are there more than 4 entries per corner ? Its not a problem can display up to about 20. Edited September 21, 2023 by BIGAL Quote
Ciupanezul21 Posted October 17, 2023 Author Posted October 17, 2023 Thanks @BIGAL for the help, but in the meantime I succeededuntil the end I managed to do it ok (defun c:AUTODIMENSIONARE (/ *error* dxfGroup getPLPoints MkBoundingBox growBound orgCoords nearCor findBL plineOrg sublist k*bulge rtd dist ang distHor distVer getMid drawDim drawDiam echo os pre style lay i j k entAll entCurr shape ConturBorder ConturBorderPts bounding ofstTYP holes fuzz A B C D E F G H ) (vl-load-com) (setq echo (getvar "CMDECHO") os (getvar "OSMODE") pre (getvar "DIMPOST") style (getvar "DIMTXSTY") lay (getvar "CLAYER") );setq (defun *error* (msg) (setvar "CMDECHO" echo) (setvar "OSMODE" os) (setvar "DIMPOST" pre) (setvar "DIMTXSTY" style) (setvar "CLAYER" lay) (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and msg (null (member msg '("Function cancelled" "quit / exit abort"))) );and (progn (alert (strcat "\nError Processing Shape:\n" msg)) (setvar "CMDECHO" 0) (command-s "_.UNDO" "") (setvar "CMDECHO" echo)) );if (exit) );defun (defun dxfGroup (code entCurr) ;Returns the value in a specified DXF Group Code ;Refer to http://www.jefferypsanders.com/autolispintr_dxftbl.html for group codes ;code : Int - The group code associated value to lookup ;entCurr : Entity - The entity to look up a code in ;Returns : Various - Returns the value associated with the group code (cdr(assoc code (entget entCurr))) );defun (defun getPLPoints (pl / a b) ;Creates a list of coordinates for all the vertexes in a given polyline ;May need to follow up with orgCoords below to ensure that the points are in order ;pl : Entity - A polyline entity in the drawing ;Returns : List - A list of coordinates ((x1 y1) (x2 y2) ...) in the polyline (setq b (list)) (foreach a pl (if(= 10 (car a)) (setq b (append b (list (cdr a)) );append );setq );if );foreach b );defun (defun MkBoundingBox (pts / a minX minY maxX maxY) ;Creates a bounding box around the furthest points of a polyline ;TODO: make this recognize arcs in a polyline and treat them appropriately ;pts : List - A list of coordinates ((x1 y1) (x2 y2) ...) in a polyline (does NOT accept a polyline entity) ;Returns : List - A list of coordinates ((x1 y1) (x2 y2)) that make up a bounding box (foreach a pts (if (or (= minX nil)(< (car a) minX)) (setq minX (car a))) (if (or (= minY nil)(< (cadr a) minY)) (setq minY (cadr a))) (if (or (= maxX nil)(> (car a) maxX)) (setq maxX (car a))) (if (or (= maxY nil)(> (cadr a) maxY)) (setq maxY (cadr a))) );foreach (list (list minX minY) (list maxX maxY)) );defun (defun growBound (bounding side amount) ;Grows a bounding box by specified amount in specified direction. ;bounding : List - A list of coordinates ((x1 y1) (x2 y2)) that make up a bounding box ;side : String - A string specifying what side to grow the box (accepts "left", "bottom", "right", "top", "all") ;amount : Int - An integer for how many units to grow the box (set to 0 for default value) ;Returns : List - A new list of coordinates ((x1 y1) (x2 y2)) for the expanded bounding box (if (= amount 0) (setq amount ofstTYP) ;Default amount is 3 inches between Dimensiuni for imperial drawings. ;This ensures that linetypes align on the Dimensiuni' extension lines );if (setq bounding (list (list (if (or (= side "all") (= side "left")) (- (car (car bounding)) amount) (car (car bounding)) ;left );if (if (or (= side "all") (= side "bottom")) (- (cadr (car bounding)) amount) (cadr (car bounding)) );if );list (list (if (or (= side "all") (= side "right")) (+ (car (cadr bounding)) amount) (car (cadr bounding)) );if (if (or (= side "all") (= side "top")) (+ (cadr (cadr bounding)) amount) (cadr (cadr bounding)) );if );list );list );setq bounding );defun (defun orgCoords (lst corner /) ;Accepts a list of coordinates and a "corner" in form of string as a sorting priority. ;Sorting priority should be "BL" (Bottom Left), "TR" (Top Right), "LT" (Left Top), etc. ;First letter in sorting priority will have higher weight than second when values are equal ;e.g. BL will put the smallest Y values first. If two Y values are equal, it will sort by smallest X ; LB will put the smallest X values first. If two X values are equal, it will sort by smallest Y ;lst : List - A list of coordinates ((x1 y1) (x2 y2) ...) for sorting ;corner : String - A string specifying corner sorting priority ;Returns : List - A sorted list of coordinates ((x1 y1) (x2 y2) ...) (defun compare-points (a b) (cond ( (= corner "BL") (if (equal (cadr a) (cadr b) fuzz) (< (car a) (car b) ) (< (cadr a) (cadr b))) ) ( (= corner "BR") (if (equal (cadr a) (cadr b) fuzz) (> (car a) (car b) ) (< (cadr a) (cadr b))) ) ( (= corner "TL") (if (equal (cadr a) (cadr b) fuzz) (< (car a) (car b) ) (> (cadr a) (cadr b))) ) ( (= corner "TR") (if (equal (cadr a) (cadr b) fuzz) (> (car a) (car b) ) (> (cadr a) (cadr b))) ) ( (= corner "LB") (if (equal (car a) (car b) fuzz) (< (cadr a) (cadr b)) (< (car a) (car b) )) ) ( (= corner "RB") (if (equal (car a) (car b) fuzz) (< (cadr a) (cadr b)) (> (car a) (car b) )) ) ( (= corner "LT") (if (equal (car a) (car b) fuzz) (> (cadr a) (cadr b)) (< (car a) (car b) )) ) ( (= corner "RT") (if (equal (car a) (car b) fuzz) (> (cadr a) (cadr b)) (> (car a) (car b) )) ) );cond );defun (vl-sort lst 'compare-points) );defun (defun nearCor (coor / j x) ;Find the coordinates of the nearest corner on ConturBorderPts to the given coords (x y) ;coor : List - Coordinates (x y) to check ;Returns : List - Coordinates (x y) of nearest corner on ConturBorderPts (setq x (car ConturBorderPts)) (foreach j (cdr ConturBorderPts) (if (< (dist coor j) (dist coor x)) (setq x j)) );foreach x );defun (defun findBL (pl / a b c) ;Find the coordinates of the bottom-left most point on a polyline ;finds smallest Y-Value first, then smallest X-Value ;pl : List - a list of coordinates ((x1 y1) (x2 y2) ...) in a polyline (does NOT accept a polyline entity) ;Returns : List - Coordinates (x y) of the bottom-left most corner (foreach a pl (if (or (= b nil)(< (cadr a) b)) (setq b (cadr a)))) (foreach a pl (if (= b (cadr a)) (if (or (= c nil)(< (car a) c)) (setq c (car a))))) (list c b) );defun (defun plineOrg (pt pl / plst norm nb n blst pa d1 d2 d3) ;PlineOrg (2.0) -Gilles Chanteau- 15/09/2007 (Modified) ;Changes the start point of a closed polyline ;pl : Entity - A polyline entity in drawing ;pt : List - Coordinates of the new start point on the polyline (if (and (setq pl (vlax-ename->vla-object pl)) (= (vla-get-ObjectName pl) "AcDbPolyline") (= (vla-get-Closed pl) :vlax-true) );and (progn (setq plst (vlax-get pl 'Coordinates) norm (vlax-get pl 'Normal) pt (trans pt 1 0) pa (vlax-curve-getParamAtPoint pl pt) nb (/ (length plst) 2) n nb );setq (repeat n (setq blst (cons (vla-getBulge pl (setq n (1- n))) blst)) );repeat (if (= pa (fix pa)) (setq n (fix pa) plst (append (sublist plst (* 2 n) nil) (sublist plst 0 (* 2 n)) );append blst (append (sublist blst n nil) (sublist blst 0 n)) );setq (setq n (1+ (fix pa)) d3 (vlax-curve-getDistAtParam pl n) d2 (- d3 (vlax-curve-getDistAtPoint pl pt)) d3 (- d3 (vlax-curve-getDistAtParam pl (1- n))) d1 (- d3 d2) pt (trans pt 0 (vlax-get pl 'Normal)) plst (append (list (car pt) (cadr pt)) (sublist plst (* 2 n) nil) (sublist plst 0 (* 2 n)) );append blst (append (list (k*bulge (nth (1- n) blst) (/ d2 d3))) (sublist blst n nil) (sublist blst 0 (1- n)) (list (k*bulge (nth (1- n) blst) (/ d1 d3))) );append );setq );if (vlax-put pl 'coordinates plst) (repeat (setq n (length blst)) (vla-setBulge pl (setq n (1- n)) (nth n blst)) );repeat );progn (prompt "\nUnvalid entity.") );if );defun (defun sublist (lst start leng / n r) ;Returns a sublist of defined position and length from a given list ;lst : List - Target list ;start : Int - Start index for the sub-list (first item = 0) ;leng : Int - Sub-list length (or nil) ;Examples: ;(sublist '(1 2 3 4 5 6) 2 2) -> (3 4) ;(sublist '(1 2 3 4 5 6) 2 nil) -> (3 4 5 6) (if (or (not leng) (< (- (length lst) start) leng)) (setq leng (- (length lst) start)) );if (setq n (+ start leng)) (repeat leng (setq r (cons (nth (setq n (1- n)) lst) r)) );repeat );defun (defun k*bulge (b k / a) ;Returns a bulge which is proportional to a reference ;Arguments : : the reference bulge ;k : the ratio (between angles or arcs length) (setq a (atan b)) (/ (sin (* k a)) (cos (* k a))) );defun (defun dist (a b) ;Find the distance btween two points ;a : List - First set of coordinates (x1 y2) : List - Second set of coordinates (x2 y2) ;Returns : Real - Aligned distance between two points (sqrt (+ (expt (- (car a) (car b)) 2) (expt (- (cadr a) (cadr b)) 2))) );defun (defun ang (a b c) ;Vector calculus to determine angle from three points, converted from radians to degrees ;a : List - First set of coordinates (x y) : List - Second set of coordinates (x y), this is the vertex of the angle ;c : List - Third set of coordinates (x y) ;Returns : Real - Degrees of the angle (defun acos (a) (atan (sqrt (- 1 (* a a))) a) );defun (* 180.0 (/ (acos (/ (- (+ (expt (dist b a) 2) (expt (dist b c) 2)) (expt (dist a c) 2)) (* 2 (dist b a) (dist b c)))) pi)) ;radians> (acos (/ (- (+ (expt (dist b a) 2) (expt (dist b c) 2)) (expt (dist a c) 2)) (* 2 (dist b a) (dist b c)))) );defun (defun distHor (a b) ;Find the horizontal distance between two points ;a : List - First set of coordinates (x y) : List - Second set of coordinates (x y) ;Returns : Real - Horizontal distance between two points (abs (- (car a) (car b))) );defun (defun distVer (a b) ;Find the vertical distance between two points ;a : List - First set of coordinates (x y) : List - Second set of coordinates (x y) ;Returns : Real - Vertical distance between two points (abs (- (cadr a) (cadr b))) );defun (defun getMid (a b) ;Find the coordinates of a midpoint between two points ;a : List - First set of coordinates (x y) : List - Second set of coordinates (x y) ;Returns : List - Coordinates of the midpoint (x y) (list (/ (+ (car a) (car b)) 2) (/ (+ (cadr a) (cadr b)) 2)) );defun (defun drawDim (a b ofst side prefix /) ;Draws a dimension string from two points ;a : List - First extension line coordinates (x y) : List - Second extension line coordinates (x y) ;ofst : List - Bounding box list of coordinates ((x1 y1)(x2 y2)) ;side : String - Side of shape to place dimension. Accepts "left", "bottom", "right" & "top" ;prefix : String - Prefix for OldCastle Shape required sides. Should be in form: "B=<>". pass nil for no prefix. (cond ( (= side "left") (setq ofst (list (car (car ofst)) (cadr (getMid a b)))) ) ( (= side "bottom") (setq ofst (list (car (getMid a b)) (cadr (car ofst)))) ) ( (= side "right") (setq ofst (list (car (cadr ofst)) (cadr (getMid a b)))) ) ( (= side "top") (setq ofst (list (car (getMid a b)) (cadr (cadr ofst)))) ) ;ofst arg when brought in is two points that create a bounding box. ;This cond changes ofst var to a list where one value is the appropriate offset ;required for the dimension and the other is the mid point (x or y depending) between ;points A and B. This ensures that a horizontal dim is not used in place of a vertical or vice versa );cond (setvar "OSMODE" 0) (if (not (null prefix)) (setvar "DIMPOST" prefix)) (if (not (null prefix)) (setvar "DIMTXSTY" "Arial")) (if (or (= side "left") (= side "right")) (command "_.DIMLINEAR" a b "angle" "90" ofst) (command "_.DIMLINEAR" a b ofst) );if (setvar "DIMPOST" pre) (setvar "DIMTXSTY" style) );defun (defun drawDiam (circle / pt-on-circle pt-for-dim) ;Draws a diameter dimension on a specified circle ;circle : Entity - An entity assignment for a circle in the drawing (setq pt-for-dim (list (+ 1 (car (dxfGroup 10 circle))) (+ 1 (cadr (dxfGroup 10 circle))))) (setvar "OSMODE" 0) (if (= "CIRCLE" (cdr (assoc 0 (entget circle)))) ;is it really a circle? (setq pt-on-circle (polar (cdr (assoc 10 (entget circle))) ;get circle's centre point (cdr (assoc 40 (entget circle))) ;get circle's radius (* pi 0.5)) ;45° );setq );if (command "_.DIMDIAMETER" (list circle pt-on-circle) "_none" pt-for-dim) ;just object is not enough, some commands needs both ename and point, combined into list '(ename (10 10 0)) );defun ;====ACTUAL PROGRAM BELOW====; (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (setvar "CMDECHO" 0) (setvar "CLAYER" "Dimensiuni") (if (setq entAll (ssget)) (progn (setq i 0 ConturBorder nil holes (list) fuzz 1.0e-6 ofstTYP 75 );setq (while (< i (sslength entAll)) ; Iterates through selected entities (setq entCurr (ssname entAll i) i (1+ i) );setq (if (= (dxfGroup 8 entCurr) "Contur") ;Looks for object on layer 'Contur'. ;Only one object should exist on Contur layer per panel (progn (if (= ConturBorder nil) (setq ConturBorder entCurr) (*error* "\nToo many Contur borders selected! Check if your polyline has been joined!") ;throws error if more than one object on Contur layer exists );if );progn );if (if (= (dxfGroup 0 entCurr) "INSERT") ;if entCurr type = Block (if (= (vla-get-effectivename (vlax-ename->vla-object entCurr)) "ShapeSymbol") ;checks if block name is "ShapeSymbol" and then saves the Tag attribute value to var "shape" (progn (setq entCurr (entnext entCurr)) (while (not (eq "SEQEND" (dxfGroup 0 entCurr))) ;"SEQEND" = end of attributes in block (setq entCurr (entnext entCurr)) (if (= (dxfGroup 2 entCurr) "Tag") (setq shape (dxfGroup 1 entCurr))) );while );progn );if );if (if (= (dxfGroup 0 entCurr) "CIRCLE") (if (= (dxfGroup 8 entCurr) "gaurire") (progn (setq holes (cons (list (car (dxfGroup 10 entCurr)) (cadr (dxfGroup 10 entCurr))) holes)) (drawDiam entCurr) );progn );if );if );while (if (= ConturBorder nil) (*error* "\nNo Contur border selected! Check your layers. Contur must be on 'Contur' layer.")) ;throws error if no objects on 'Contur' layer existed in selection set (if (/= (dxfGroup 0 ConturBorder) "LWPOLYLINE") (*error* "\nContur border is not a polyline! Check if your Contur has been joined.")) ;throws error the object on layer 'Contur' is not a polyline (if (/= (logand (dxfGroup 70 ConturBorder) 1) 1) (*error* "\nContur polyline is not closed! Check all corners of Contur before dimensioning.")) ;throws an error if Contur border does not have logical bitwise value of 1, denoting a closed polyline (setq ConturBorderPts (getPLPoints (entget ConturBorder))) (plineOrg (findBL ConturBorderPts) ConturBorder) ;recreates ConturBorder polyline to ensure that the origin is at the bottom left of the shape (Point "A") ;this will fail on shapes with no flat bottom ;TODO: create exceptions for shape 51, 61, 62, 64, 65, 75. (setq ConturBorderPts (getPLPoints (entget ConturBorder))) (if (>= (cadr (car ConturBorderPts)) (cadr (cadr ConturBorderPts))) (progn (command ".pedit" ConturBorder "reverse" "") (plineOrg (findBL ConturBorderPts) ConturBorder) (setq ConturBorderPts (getPLPoints (entget ConturBorder))) (prompt "\nPolyline is backwards. Reversing") );progn );if ;checks if polyline is drawn clockwise from origin by checking if point B is greater than point A (setq bounding (MkBoundingBox ConturBorderPts)) (setq bounding (growBound bounding "all" 0)) (setq i 0 j 0) (foreach j ConturBorderPts (cond ;( (= i 0) (progn (setq A j) (command "-TEXT" A "1.5" "0" "A")) ) ;( (= i 1) (progn (setq B j) (command "-TEXT" B "1.5" "0" "B")) ) ;( (= i 2) (progn (setq C j) (command "-TEXT" C "1.5" "0" "C")) ) ;( (= i 3) (progn (setq D j) (command "-TEXT" D "1.5" "0" "D")) ) ;( (= i 4) (progn (setq E j) (command "-TEXT" E "1.5" "0" "E")) ) ;( (= i 5) (progn (setq F j) (command "-TEXT" F "1.5" "0" "F")) ) ;( (= i 6) (progn (setq G j) (command "-TEXT" G "1.5" "0" "G")) ) ;( (= i 7) (progn (setq H j) (command "-TEXT" H "1.5" "0" "H")) ) ( (= i 0) (setq A j) ) ( (= i 1) (setq B j) ) ( (= i 2) (setq C j) ) ( (= i 3) (setq D j) ) ( (= i 4) (setq E j) ) ( (= i 5) (setq F j) ) ( (= i 6) (setq G j) ) ( (= i 7) (setq H j) ) );cond (setq i (1+ i)) );foreach (if holes (progn (setq holes (orgCoords holes "LB") i 0 );setq (foreach j holes (setq i (1+ i)) (if (not (equal (car j) (car (nth i holes)))) (progn (drawDim a j bounding "bottom" nil) (setq bounding (growBound bounding "bottom" 0)) );progn );if );foreach (setq holes (orgCoords holes "BL") i 0 );setq (foreach j holes (setq i (1+ i)) (if (not (equal (cadr j) (cadr (nth i holes)))) (progn (drawDim a j bounding "left" nil) (setq bounding (growBound bounding "left" 0)) );progn );if );foreach ));progn;if ;(if holes ; (progn ; (setq holes (orgCoords holes "LB") ; i 0 ; k 0) ; (foreach j holes ; (setq i (1+ i)) ; (cond ; ( (and (equal (nearCor j) a fuzz) (not (equal (car j) (car (nth i holes))))) ; (setq k (1+ k)) ; (drawDim j a (growBound bounding "bottom" (* ofstTYP k)) "bottom" nil) ; ; ) ; );cond ; );foreach ; );progn ;);if (drawDim a d bounding "bottom" "B=<>") (drawDim a b bounding "left" "L=<>") ) );cond );progn (print "Invalid selection!") );if (*error* nil) (princ) );defun Quote
