In the case of Clint’s post, I don’t know that BricsCAD has ODBX
Indeed it does! I had tried to get implement this in Python, but there was no public interface, same with the other clones. I wonder if it’s hidden in lisp?
Does this work in BricsCAD?
I did a quick search before starting on this method and it showed ODBX in BricsCAD for a few versions back, but wasn't 100% sure.
The OP used AutoCAD 2021 when this thread was started and I only have AutoCAD to test with, so it is what it is.
This program might could be made a little faster and cleaner, though plenty fast enough for me.
I made some headway yesterday on doing the multi-file batch convertor, I may have to do some work they pay me to do today, though.
I am still waiting on the answers from my latest Request for Information, I might be able to do some more testing until then.
I'm positive they will respond and ask for finished drawings 5 minutes later.
I will probably continue this on my original thread I created for the older convertors.
Drawing Batch Converters - AutoLISP, Visual LISP & DCL - AutoCAD Forums
I just had AI write a test to see if ODBX worked.
(defun c:TestDbx ( / dbxProgId dbxDoc extFile)
  (vl-load-com)
  (if (vl-string-search "BricsCAD" (getvar "PROGRAM"))
    (setq dbxProgId "ObjectDBX.AxDbDocument")
    (setq dbxProgId (strcat "ObjectDBX.AxDbDocument." (substr (getvar "ACADVER") 1 2)))
  (setq dbxDoc (vl-catch-all-apply 'vla-GetInterfaceObject
                 (list (vlax-get-acad-object) dbxProgId)))
  (if (vl-catch-all-error-p dbxDoc)
      (princ (strcat "\nError: Could not load interface using ProgID: " dbxProgId))
      (princ (strcat "\nDetails: " (vl-catch-all-error-message dbxDoc)))
      (setq extFile (getfiled "Select Drawing to Read" "" "dwg" 0))
      (if extFile
          (vla-open dbxDoc extFile)
          (princ (strcat "\nSuccess! Total objects in Model Space: "
                         (itoa (vla-get-count (vla-get-modelspace dbxDoc)))))
        (princ "\nNo file selected.")
      (vlax-release-object dbxDoc)
I suppose if time allows I could work out to get it working for other CAD that use ODBX.
After all, that is my reasoning on eliminating the use of Express Tools, make it more universal.
Without having anything else to test I would need testing volunteers with appropriate CAD platform.
Maybe at some point I could download the trial version if they have them.
AutoCAD
Command: TESTDBX
Success! Total objects in Model Space: 41769
BricsCAD
: TESTDBX
I didn't try ZwCAD or GstarCAD
  • Thanks 1
