0misclose Posted January 2, 2024 Posted January 2, 2024 Hi all, I'm quite new to Civil 3D and I've tried to have a look online to find what I'm looking for but I feel it might be easier to just ask. I'm wanting to generate a surface model of a complex feature survey which I currently have in AutoCad. All the 3D linework for kerbs, retaining walls, footpaths etc. as well as spot heights are already in the AutoCad file (due to the nature of the project the workflow isn't very nice and predominantly involves DXFs which are then stitched into the main file and the layers are adjusted afterwards). I don't have any codes or data input workflows setup within Civil 3D. I have another survey software package that I normally use to generate my surface models but it will be very time consuming to import the DWG and set it up beforehand due to the scale and amount of breaklines so I was curious if it would be easier for me to try and do it in Civil 3D (it might not). How easy is it to take 3D polylines, splines, lines and points from a DWG and generate a surface in Civil 3D? Is it possible to select all the lines and ensure they are breaklines? Are you able to make select layers non-contourable? How easy is it to generate model boundaries? I would greatly appreciate any guidance. Regards, Ryan Quote
CyberAngel Posted January 2, 2024 Posted January 2, 2024 First, create the surface in the Prospector (which is in your Toolspace). To do this, right-click on Surfaces and select Create Surface. You don't add any information to it in this step, just give it a name. Second, expand the Definition for the surface (still in your Prospector). You'll see a list of object types you can add to the surface, such as points, contours, and breaklines. Select the points (for instance) you want to use, right-click on the Points item, and tell it to Add. Do the same for breaklines or whatever else you need. If the items you need to add are on different layers, it may help to isolate them before you select. Don't worry about getting your surface exactly right on the first try. You can always close the drawing without saving (you saved first, right?) or edit the surface afterward. To get a look at the surface itself, select it and use the 3DORBIT command. You'll probably have questions. We''re here to help. 1 Quote
BIGAL Posted January 2, 2024 Posted January 2, 2024 (edited) You may have to resort like CyberAngle to make points for all the vertices of the objects, like 3dpolys, Lines etc, the spline need to make points along the spline else will not represent the shape.. This will allow read of all 3D points into a surface, you will then need to add breaklines. Your surface should then be correct. If as suggested you have contours but it sounds like these again are actually plines hopefully with an elevation. If they are at RL 0.0 but labelled then can move to correct Z then make points, not easy to automate. Do you have anything to add 3dpoints to objects ? Edited January 2, 2024 by BIGAL Quote
srleone Posted January 28 Posted January 28 What is CyberAngle? Thanks, Su Leone, PLS Raleigh NC Quote
CyberAngel Posted January 29 Posted January 29 On 1/28/2026 at 7:58 AM, srleone said: What is CyberAngle? Thanks, Su Leone, PLS Raleigh NC "CyberAngle" is me Quote
tombu Posted January 30 Posted January 30 On 1/1/2024 at 7:05 PM, 0misclose said: I'm quite new to Civil 3D and I've tried to have a look online to find what I'm looking for but I feel it might be easier to just ask. I have another survey software package that I normally use to generate my surface models but it will be very time consuming to import the DWG and set it up beforehand due to the scale and amount of breaklines so I was curious if it would be easier for me to try and do it in Civil 3D (it might not). I would greatly appreciate any guidance. Regards, Ryan You should be creating your surface in Civil 3D instead as it would be much more accurate than whatever survey software package you're using. Feature lines in Civil 3D for pavement swales etc… are intelligent objects that allow curve sections with elevations not possible with the breaklines your software or even AutoCAD objects could possibly do. Civil 3D surfaces are also intelligent objects as well. You've got a pretty expensive software Autodesk package. Doesn't make sense to not take advantage of it. It may seem daunting to learn but once you have your templates with styles set up importing survey data and creating and displaying objects and features with surfaces and contours should only take a few minutes. Obviously as it's completely different than what you're doing now there will be a lot to learn but Civil 3D includes a lot of Help and Tutorials. Quote
BIGAL Posted January 30 Posted January 30 "complex feature survey" one of the things not mentioned is the import from your total station data recorder, this way all line work is strung automatically, points set contourable or not, blocks inserted on those points and breaklines say by layer naming can be set. Do you have access to the field data, which total station ? There should be people here who can provide a CIV3D dwt set up for you to match your total station. Something I have and Autodesk did not do it is Import Description Keys, from Excel. You can export but not import. 1 Quote
