David B. Posted February 9 Share Posted February 9 Good afternoon, One of our vendors has sent us several shp files with lines/polylines and ones with points. All the data comes in on a single layer, but I would like to sort the data with a LISP based on existing layers I've created and some of the Object data. Below is an example of the OD I want to use, and the layers I would like to have the objects sorted into. Could anyone help with some code that I could use to sort these objects? The OD table name will change depending on the file we receive, if that matters. Thanks Quote Link to comment Share on other sites More sharing options...
devitg Posted February 11 Share Posted February 11 @David B.Please upload your sample.dwg Quote Link to comment Share on other sites More sharing options...
