Hdong Posted April 17 Posted April 17 On 3/4/2024 at 11:32 PM, fuccaro said: Try this: (defun c:pp( / ss) (setq ss (ssget "_:L" '((0 . "INSERT")(2 . "PLANT")(66 . 1))) sum 0) (repeat (setq i (sslength ss)) (setq b1 (ssname ss (setq i (1- i)))) (while (and (/= (cdr (assoc 0 (setq b1l (entget b1)))) "SEQEND") (/= (cdr (assoc 2 b1l)) "PLANTGPM")) (setq b1 (entnext b1)) ) (setq n1 (read (cdr (assoc 1 b1l))) sum (+ sum n1)) ) ) Welcome in the Forum! Hi, I am new to this post and found this lisp works great as I wish. Is it possible to make it select one time with varies attribute blocks ? Thank you so much Hung Quote
mhupp Posted April 17 Posted April 17 (edited) This uses nentsel to select the attribute iteslf inside the block along with a while loop to keep adding to sum until you not select anything. untested & done in notepad. BlockSum.lsp Edited April 17 by mhupp 1 Quote
BIGAL Posted April 19 Posted April 19 @mhupp has given you a good answer, if you have say one block name but inserted multiple times and want to add the same attribute from all those blocks it can be done with a single pick that returns block name and attribute tag name, then just select blocks and a sum will be produced, @mhupp has a good check is it a number in his code. Can you confirm what it is exactly your asking for. Quote
