Modify Autocad submenu through Lisp
Jerry381
Hi everyone, I need to modify some options in the "Automatic Publish" submenu through a lisp or if not possible through a script, in detail I should modify the "Type" section from the "Multi-sheet" file to "Single-sheet file" and vice versa
does anyone know if it's possible?
Many thanks in advance
actually I use an Excel macro to create a batch of prints where it opens a series of DWGs and then closes them all, in this way with the submenu setting of "Automatic Publish" set to Close it prints each one in PDF , my problem is that I would like to set that setting to close and the type in Multi-sheet" file or "Single-sheet file" (if I want to make a single PDF or multiple sheets) with a lisp called from the print script or if not possible directly within the print script
