Example .NET Jigging: A parabola parable
  • 1 year later...
  • Replies 56
  • SEANT
    26
  • Lee Mac
    16
  • wannabe
    6
  • khoshravan
    4
Posted Images
Attached is the source code as well as a compiled dll if anyone is willing to give it a test drive.
http://www.cadtutor.net/forum/showpost.php?p=233991&postcount=34
Sorry for newbe level question. I DL your file. How can I use (perhaps import) them in ACAD?
Also you put the source code in a txt file. Is it easier to use it comparing to dll file? How can I use this one?
The DLL is more easily used. It is loaded via:
Command: [color="green"]netload[/color]
Browse for CsParabola.dll
Then, to run the commands either:
Command: [color="Green"]pvf[/color]
For parabola via vertex and focus selection, or:
Command: [color="green"]pbb[/color]
For parabola by bounding box selection.
I haven’t been able to test this on AutoCAD 2007. Please let me know how it performs.
Another note; Direct Distance Entry is not yet implemented.
I tried it but it gave following error message:
Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Exception has been thrown by the target of an invocation.
Details Continue
I clicked continue but it returned the command prompt.
In detail it says:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
It it goes OK, is it necessary to load it each time?
One detail that I failed to mention is that CsParabola.dll needs to be on a local drive (not run from some server location). I’m not sure, though, if that is the problem or not.
The only way to know with certainty is to debug the code with AutoCAD 2007. The only version I have available is 2009.
If someone has Visual Studio 2005/2008, along with AutoCAD 2007, and is willing to give the routine some attention, I’ll gladly upload all project files.
I have DL the file to my laptop and opened it. I do not use it from a server location.
Rasoul
What does this statement mean exactly?
The DLL would require loading for each new launch of AutoCAD. The routine would then be accessible to all loaded drawings.
.NET DLLs, like ObjectARX routines, can be set up for Demand Load (i.e., loaded the first time the command is called). It does require a change to the system registry on the user’s computer. I haven’t gone that route yet as I suspect that may cross bounds set by IT dept.
Hi Seant,
The error is due to the fact the Dimension.DynamicDimension property isn't available in the 2007 SDK.
Ah yes, that would do it. I’ll look into removing that for a 2007 compatible version and post it when ready.
Thanks, gile.
Sorry for miss print
The correct is:
If it goes OK,
Here is a re-tooled version that will (hopefully) run on AutoCAD 2007 through present. Any feedback will be appreciated.
Parabola_2007Comp.zip
  • 10 years later...
Hi, thanks for your sharing. But I cannot right load the plugin into CAD2021 version. After the netload command, there is nothing happened. the command pbb and pvf cannot be found either.
I do do not have access to ACAD 2021 version - to know for certain -  but I suspect the routine will work fine.  The first thing I would recommend is UnBlocking the file.  That is a MS Windows requirement for all 'DLLs' originating from outside locations.
Edited by SEANT
Fixed Typo
As a side note - this thread goes way far back.  Over 10 years ago.  Back when there wasn't even a dedicated category for .NET automation.  It's location in the AutoLisp forum may seem rather odd.
Moved to .NET, ObjectARX & VBA Forum.
Quote
I do do not have access to ACAD 2021 version - to now for certain -  but I suspect the routine will work fine.  The first thing I would recommend is UnBlocking the file.  That is a MS Windows requirement for all 'DLLs' originating from outside locations.
Thanks for your kindly reply. I think I didn't block the routine files. I unzip the file and get CsParabola.dll and CsParabola.pdb, and use the netload command to load CsParabola.dll. After run the command of "netload", there is not any message about the load result. Then I try to input the command "pbb" and "pvf", but it seems that there are no such commands. I suppose the netload command didn't succeed, and doesn't know how to deal with it.
Sorry, I am a freshman to advance functions of AutoCAD, maybe this question seems silly. But I really need this routine to get a parabola shape. I would greatly appreciate your help
Edited by joeshardow
add the quote
9 hours ago, joeshardow said:
. . . . I think I didn't block the routine files. . . .
This statement is confusing.
Ideally what should happen:
Download the Zip file
Using 'File Explorer', navigate to downloaded file and Unzip
Navigate to the generated zip generated folder
Right click on the DLL and select 'Properties' in the drop down menu - you should see something like the attached image
Check 'Unblock'
Move the DLL to the folder where your version of the 'acad.exe' resides (Usually something like Program Files - Autodesk - AutoCAD 2021)
In AutoCAD, Netload the DLL from that file location.
