Jadeous, please try this:
(defun c:reNum  (/ ENT I SS)
 (vl-load-com)
 (or sNum (setq sNum 1)) (or inNum (setq inNum 1))
 (setq sNum  (cond ( (getreal (strcat "\nSpecify Starting Number <" (rtos sNum 2 2) ">: "))) (sNum))
       inNum (cond ( (getreal (strcat "\nSpecify Increment <" (rtos inNum 2 2) ">: "))) (inNum))
       Pref  (getstring t (strcat "\nSpecify Prefix <-None->: "))
       Suff  (getstring t (strcat "\nSpecify Suffix <-None->: ")))
 (if (setq i -1 ss (ssget '((0 . "INSERT") (66 . 1))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (foreach att (vlax-invoke (vlax-ename->vla-object ent) 'GetAttributes)
       (cond (  (eq "POINT" (strcase (vla-get-TagString att)))
                (vla-put-TextString att (strcat Pref (rtos sNum) Suff))
                (setq sNum (+ sNum inNum)))))))
 (princ))
Its pretty much what I posted above though. :geek:
  • Replies 23
  • Jadeous
    12
  • Lee Mac
    10
  • ILoveMadoka
    1
  • uddfl
    1
Posted Images
Hello Lee Mac. The first lisp in this thread is the one the worked in 2006. The longer one, not the short one. The short never worked for me. I posted a new thread that has a better explaination.
Its called, "Old Lisp Doesn't Work in 2008 ACAD"
What error do you get?
Does it still error with the above post?
  • 3 years later...
I figured I would revisit this older post of mine to thank LeeMac for the above mentioned lisp routine. I have been using it for several years and I love it.
Now I have discovered how to attach blocks to Multileaders with attribute text inside them. This is the time I miss my dear Renum lisp. It works on regular blocks and such, but not multileaders...
I am working with hundreds of these Weld Joint Number multileaders and I have to change them one by one. It takes quite awhile.
I was hoping someone could maybe adjust the current "renum" lisp I have to work on multileaders as well. I have attached the block I am using for the multileader.
any help would be great. Thank you.
Weld Joint Number.dwg
