Berzerker Posted June 22, 2025 Author Posted June 22, 2025 (edited) Take a look at the lines on the corner. That doesn't look right to me. Here's the drawing Mindblower 5.0 speaker bottom cover fix.dwg Edited June 22, 2025 by Berzerker Quote
ReMark Posted June 22, 2025 Posted June 22, 2025 (edited) "How to Use the #D Fillet Command in AutoCAD 2007" as posted on YouTube. Here is the link. Note: Way up at the top left-hand corner it says AutoCAD 2007 - (Drawing1.dwg). Edited June 22, 2025 by ReMark Quote
Berzerker Posted June 22, 2025 Author Posted June 22, 2025 Something has happened to the solid cover. It's corrupt or something. I tried that yesterday and it didn't work. So, I tried it on another solid in the drawing and it worked. Now that I know a different way I can easily make it over and will take a tenth of the time. Thanks ReMark and SLW210 I wish someone had told me this years ago. Quote
Berzerker Posted June 22, 2025 Author Posted June 22, 2025 (edited) One more, Am I to assume that if fillet rounds edges in 3D that chamfer will do the same at the base of built in spacers? Where I don't have to create a shape, revolve it and then place it and union it? pictured here: Edited June 22, 2025 by Berzerker Quote
ReMark Posted June 22, 2025 Posted June 22, 2025 (edited) Chamfer will put a beveled edge on an object. There will be no voids to fill in or worry about. Edited June 22, 2025 by ReMark Quote
SLW210 Posted June 22, 2025 Posted June 22, 2025 Yes, you can chamfer as well. Yes, you have issues with the solid in the drawing you posted. Most likely from trying the subtract and union. You are correct, you should be able to start over and do a better job. If you hit a snag just ask questions and post the .dwg if you need the solid looked over. Quote
Berzerker Posted June 22, 2025 Author Posted June 22, 2025 Thanks SLW210 I kinda figured that when it would work on one solid and not the other. Not my first rodeo on messing up a drawing. There was a knurled roller I wanted to draw in 3D once ... let's just say I saved it a reminder not to try to let AutoCad render to many surfaces in a drawing. it crashes upon start up. At least that was my guess. Quote
SLW210 Posted June 23, 2025 Posted June 23, 2025 Let us know how it comes out and if it 3D prints well. What 3D printer do you use and how do you like it? I've going through various reviews and testing sights trying to determine which to buy, the tech is improving and prices were decent for some well reviewed models/brands. Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 It's an old Creality and it needs some new parts. You have to baby it, and it takes time to print, or should I say I make it print slow, so it doesn't get confused. I really like the look of the new enclosed Creality's but I'm not a hard core Creality fan. I'm looking too for a new one. Also $700.00 to $1000* with accessories is within my budget (It's a hobby). There are some expensive one's out there. The last cover I tried to print on it leaned to one side (also not a professional 3D printer) and it is second hand. But I am used to the software. A little about me I'm 64 and retired. Most my jobs were around machinery. I never learnt electronics, so I started learning because I wanted to remake a favorite from my past. This is just one part of that project. Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 I have a few more post here where you, ReMark and several others have helped me before. Lofting and revolving were amazing tools to learn for a newbie like me. With several corrupt drawing restarts, I got here: Mindblower 5.0 speaker amp assy.dwg Quote
SLW210 Posted June 23, 2025 Posted June 23, 2025 Same age, but working still. 3D printing will be mostly a hobby. Grandkids particularly my grandson wants to do some 3D printing. Hopefully that budget works for something decent, I could go more, but wouldn't want to if that gets a reliable machine. That's pretty good work, IMHO. Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 Haven't attached any materials really. So, it isn't realistic. Just some standard color to know the difference in the parts, where they go and make sure they fit. Already spent about $200-$250 including speakers. Sooo, I guess I'm in too far to back up now. Here never a dull moment ... I went to put out garbage and left the door open (Only a couple, three minutes) and closed the door coming back in. and hear something turn around and I'm in a full-blown war with a moccasin snake. I live in the country, also not my first rodeo with a snake ... he's losing! Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 The snake is in very bad shape. Don't think he knew how coming in my house would ruin his day. He's under the washer and dryer and I've haven't heard any sounds for a while and no movement. The new shovel I just bought has already been worth it. several good gashes all along his body. Not really wanting to kill the snake but he's in the house and poison. Quote
SLW210 Posted June 23, 2025 Posted June 23, 2025 I usually try to shoo them out or I have picked them up. But I did kill a Coral snake a few years ago, was getting too close to the Grandson and refused to go in another direction. Southwest Florida here, surprisingly not many get in the house, but it happens. Last one in the house was a banded water snake as I was headed to work I saw him in the dark move a little, maybe 2 1/2 to 3 ft. long. Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 Only like third or fourth in about 30 years of living here. I live smack in the middle of Alabama. I tried to get it to go back out. Even opened the door and it saw the door ... I even asked nicely. I guess we're at the FO stage of how this ends. I was planning to try and check out the new fillet command that I didn't know existed. But till I remove it dead or alive I'm having to watch around my feet and where I'm going. Quote
Berzerker Posted June 23, 2025 Author Posted June 23, 2025 (edited) While being on snake duty I managed to get and few fillets in. I've moved to the inside walls, and it keeps saying failure to fillet (invalid). I'm I missing something else or am I picking wrong or not understanding what it's wanting me to choose or how. Snake update: I still have not seen or heard anything move since the war started and I got the upper hand. This corner Also, I've set the fillet to 1/16R a 32 diameter. Do you think that's too much? The wall is only 1/8 thick. Edited June 23, 2025 by Berzerker Quote
SLW210 Posted June 24, 2025 Posted June 24, 2025 If I have issues I try a different radius. Sometimes selecting a different order helps. Most times I try working with the 2D Wireframe Visual Style to make sure I get the correct edge. Getting used to 3D Rotate comes in handy as well. P.S. I always work on a Copy of the solids, makes it easy to start over. Quote
Berzerker Posted June 24, 2025 Author Posted June 24, 2025 Morning SLW and thanks My mind wasn't exactly into it with the snake on the prowl. It's like wanting to do something and always having to look over your shoulder. I'm not scared of it, but I wouldn't wanna get bit either. I think it found a hole besides one of the water pipes or airduct for the dryer. The fillets were done in a few minutes instead of hours or days. I thought it only worked in 2D, the task of making a shape to union or subtract then placing it (barf). I know 2007 holds more secrets that I need to learn. I bet the newer versions are even more incredible. Quote
