Hi,
Is it possible to make API (web) calls using AutoLISP that work in both AutoCAD and AutoCAD LT?
If not, what is the recommended workaround for AutoCAD LT?
Thanks in advance!
Hi
I guess a necessary question is: which API calls?
If you want to access the web, look for information about XMLHTTP
Edited by GLAVCVS
Do a google lots of code out there can be as simple as.
(command "browser" "https://maps.google.com.au" )
; opera house -33.8567844,151.213108,17z
(command "browser" "https://www.google.com.au/maps/@-33.8567844,151.213108,17z")
Not tested in LT. Works in Bricscad.
Edited by BIGAL
On 6/26/2025 at 3:18 PM, GLAVCVS said:
Hi
  (setq webObj (vlax-invoke-method (vlax-get-acad-object) 'GetInterfaceObject "WinHttp.WinHttpRequest.5.1"))
  (vlax-invoke-method webObj 'Open "GET" strUrl :vlax-false)
  (setq errobj (vl-catch-all-apply 'vlax-invoke-method (list webObj 'Send)))
This code not working in AutoCAD LT.
Why doesn't 'strUrl' work?
Make sure that variable contains a valid URL.
Edited by GLAVCVS
Lt may not support "GetInterfaceObject", it is not a full lisp version lots of stuff does not work.
@p7q did you try what I posted ?
2 hours ago, SLW210 said:
Good stuff.
Here is an older example using JSON... https://github.com/diegomcas/autolisp-web-and-json-utils
Here is rundown on LT limitations... https://www.cadforum.cz/en/limitations-of-the-lisp-language-autolisp-visuallisp-autocad-lt-tip13683
IIRC you need ActiveX or other things that LT is lacking to make API calls, I hope I am proven wrong though.
You're both correct; LT now supports AutoLISP (not Visual LISP / COM). Not sure if it even supports Autoloader.
I have a customer who paid for one of my Autodesk Exchange store apps, used it for years and now his employer downgraded everyone from full AutoCAD to LT. I had offered to write a (slower but functional) Visual LISP variant of the app they purchased, but no worky.
Cheers
LT does support ActiveX/COM, but cannot interface with objects outside of the AutoCAD Object Model.
  • Like 2
Thanks for the clarification, my friend. :beer:
@BlackBox
I am glad to see you contributing once again in all around similar forums. :beer:
It's been a long time indeed.
Thanks, @Tharwat!
We had a child, who's about to start kindergarten in a few weeks, we've moved, we have new jobs... so my priorities are (I am) different.
Cheers
Good clarification.
From the link I posted.
Quote
The first type of limitation is the lack of support for external ActiveX objects. For them you cannot use the (vlax-create-object), (vlax-get-object), (vlax-get-or-create-object), (vlax-import-type-library), (vla-GetInterfaceObject) functions. These functions are typically used for online communication, clipboard handling, XML, binary files, Excel, Word, Access (or other database tools), etc. But there may be a workaround for your situation - see the Tip 14007.
 TIP 14007
