SLW210 Posted July 4, 2025 Posted July 4, 2025 20 hours ago, BlackBox said: FWIW, neither my ADN nor work's AEC Collection subscriptions give me access to LT (full versions only). Hence the reason the OP needs to respond with more than... Quote This code not working in AutoCAD LT. I could test hings in LT when I get to work, but I would only do that for my own needs. If OP wants a solution they should be more responsive, IMO. The easy solution here is upgrade those that would need to use API calls to full AutoCAD. Quote
