rlx Posted Wednesday at 08:48 PM Posted Wednesday at 08:48 PM (edited) You can try if this works better. No dbx in this version Start app , make selection , select drawing you want to paste in later. This drawing is shortly opened (not sure if it works if drawing is already open) List with blocknames is created and drawing is closed. Blocknames are compared and if duplicates are found message is displayed. You can choose 1- Stop , 2 - Rename the blocks in drawing you made the selection set (not the other drawing), or 3 - copy / paste as it is. Only thing left to do is select your basepoint (or replace 'pause' with "0,0" in the code) and selection set is placed on clipboard , ready to paste. ;;; check before paste - rlx 2025-10-22 (defun c:cbp ( / this-dwg ss other-dwg blocknames-in-selectionset blocknames-in-other-dwg duplicate-blocknames dbx-doc) (setq this-dwg (vla-get-ActiveDocument (vlax-get-acad-object))) (if (and (setq ss (ssget)) (setq other-dwg (getfiled "Drawing to check before you paste" "" "dwg" 0))) (progn (if (vl-consp (setq blocknames-in-selectionset (Get_SS_BlockNames ss))) (setq blocknames-in-selectionset (mapcar 'strcase blocknames-in-selectionset))) (if (vl-consp (setq blocknames-in-other-dwg (Get_EX_Blocknames other-dwg))) (setq blocknames-in-other-dwg (mapcar 'strcase blocknames-in-other-dwg))) (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-other-dwg)) (if (vl-consp duplicate-blocknames) (progn (dplm duplicate-blocknames "Duplicated block names : ") (setq inp (cfl (list "1 - I'm not gonna paste" "2 - Rename blocks before pasting" "3 - I'm gonna paste anyway"))) (cond ((or (void inp) (wcmatch inp "1*")) (alert "Copybase aborted")) ((wcmatch inp "2*")(foreach b duplicate-blocknames (rename_block_definition b)) (princ "\nBlocks are renamed - select your basepoint now") (command "_copybase" pause ss "")) ((wcmatch inp "3*") (princ "\nBlock names unchanged - select your basepoint now")(command "_copybase" pause ss "")) (t (princ"\nBite me...")) ) ) (progn (princ "\nNo duplicate block names found - select your basepoint")(command "_copybase" pause ss "")) ) ) ) (princ) ) ;;; get block names active doc - vanilla (defun _bl ( / b l ) (while (setq b (tblnext "BLOCK" (null b))) (if (zerop (boole 1 21 (cdr (assoc 70 b)))) (setq l (cons (cdr (assoc 2 b)) l)))) l) (defun Get_EX_Blocknames (other-dwg / fn l) (if (and (eq (type other-dwg) 'STR)(setq fn (findfile other-dwg)) (setq doc (vla-open (vla-get-documents (vlax-get-acad-object)) fn))) (progn (setq l (GetDocBlockNames doc))(vla-close doc)(vlax-release-object doc))) l) ;;; test (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) (defun GetDocBlockNames ( d / b n l) (vlax-for b (vla-get-blocks d) (if (and (= :vlax-false (vla-get-isxref b)) (= :vlax-false (vla-get-islayout b)) (not (vl-string-search "*" (setq n (vla-get-name b)))))(setq l (cons n l)))) l) (defun create_unique_blockname ( $bn / i bn) (setq i 0)(while (tblsearch "block" (setq bn (strcat $bn "_" (itoa (setq i (1+ i))))))) bn) (defun rename_block_definition ( $bn / bc bn ) (setq bc (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) (if (and (not (void $bn)) (tblsearch "block" $bn)) (vla-put-name (Collection-Member $bn bc)(setq bn (create_unique_blockname $bn)))) bn) (defun compare_block_names (a b / c) (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c) (defun Get_SS_BlockNames ( ss / n l) (foreach o (ss->ol ss)(if (and (setq n (block-n o))(not (member n l)))(setq l (cons n l)))) l) (defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun void (x) (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x))))) (defun block-n (o)(if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")) (if (vlax-property-available-p o 'EffectiveName) (vla-Get-EffectiveName o) (vla-Get-Name o)) nil)) (defun Collection-Member (m c / r) (if (vl-catch-all-error-p (setq r (vl-catch-all-apply 'vla-item (list c m)))) nil r)) ;;; display list (plus message) (defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l)))) (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";" "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb") (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f)))) ;; choose from list (cfl '("1""2""3")) (defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";width=40;}ok_cancel;}" p) (not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d) (progn (start_list "lb")(mapcar 'add_list l)(end_list)(action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)") (action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)") (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(r r)(t nil))) edit : just had an idea , why not open the 'to be pasted' drawing after you made your selection. Also tried if it was a bad thing if both drawings were already open and yes , that's bad... but then I'm a bad bad dragon (it still opens but as read only) Because I use vla-activate at the end , all lisp stops (obviously) Once drawings is activated you can copypaste / ctrl-V yourself (I'm sure as hell not comming to do that for you ) You decide what make you happy... ;;; check before paste 2 : after selection open the 'to be pasted' drawing - rlx 2025-10-22 (defun c:cbp2 ( / acDoc *docs* ss dbDoc blocknames-in-selectionset blocknames-in-dbDoc duplicate-blocknames inp do-it) (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)) *docs* (vla-get-documents (vlax-get-acad-object))) (if (and (setq ss (ssget)) (setq dbDoc (getfiled "Drawing to check before you paste" "" "dwg" 0))) (progn (if (vl-consp (setq blocknames-in-selectionset (Get_SS_BlockNames ss))) (setq blocknames-in-selectionset (mapcar 'strcase blocknames-in-selectionset))) (if (vl-consp (setq blocknames-in-dbDoc (Get_EX_Blocknames dbDoc))) (setq blocknames-in-dbDoc (mapcar 'strcase blocknames-in-dbDoc))) (setq duplicate-blocknames (compare_block_names blocknames-in-selectionset blocknames-in-dbDoc)) (if (vl-consp duplicate-blocknames) (progn (dplm duplicate-blocknames "Duplicated block names : ") (setq inp (cfl (list "1 - I'm not gonna paste" "2 - Rename blocks before pasting" "3 - I'm gonna paste anyway"))) (cond ((or (void inp) (wcmatch inp "1*")) (alert "Copybase aborted")) ((wcmatch inp "2*")(foreach b duplicate-blocknames (rename_block_definition b)) (princ "\nBlocks are renamed - select your basepoint now") ;|(command "_copybase" pause ss "")|; (setq do-it t)) ((wcmatch inp "3*") (princ "\nBlock names unchanged - select your basepoint now") ;|(command "_copybase" pause ss "")|; (setq do-it t)) (t (princ"\nBite me...")) ) ) (progn (princ "\nNo duplicate block names found - select your basepoint") ;|(command "_copybase" pause ss "")|; (setq do-it t)) ) ) ) (if do-it (do_it)) ) (defun do_it ( / f d) (command "_copybase" pause ss "")(and (eq (type dbDoc) 'STR) (setq f (findfile dbDoc))(setq d (vla-open *docs* f)))(vla-activate d)) ;;; get block names active doc - vanilla (defun _bl ( / b l ) (while (setq b (tblnext "BLOCK" (null b))) (if (zerop (boole 1 21 (cdr (assoc 70 b)))) (setq l (cons (cdr (assoc 2 b)) l)))) l) (defun Get_EX_Blocknames (dbDoc / fn l) (if (and (eq (type dbDoc) 'STR)(setq fn (findfile dbDoc)) (setq doc (vla-open (vla-get-documents (vlax-get-acad-object)) fn))) (progn (setq l (GetDocBlockNames doc))(vla-close doc)(vlax-release-object doc))) l) ;;; test (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) (defun GetDocBlockNames ( d / b n l) (vlax-for b (vla-get-blocks d) (if (and (= :vlax-false (vla-get-isxref b)) (= :vlax-false (vla-get-islayout b)) (not (vl-string-search "*" (setq n (vla-get-name b)))))(setq l (cons n l)))) l) (defun create_unique_blockname ( $bn / i bn) (setq i 0)(while (tblsearch "block" (setq bn (strcat $bn "_" (itoa (setq i (1+ i))))))) bn) (defun rename_block_definition ( $bn / bc bn ) (setq bc (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) (if (and (not (void $bn)) (tblsearch "block" $bn)) (vla-put-name (Collection-Member $bn bc)(setq bn (create_unique_blockname $bn)))) bn) (defun compare_block_names (a b / c) (and (vl-consp a) (vl-consp b) (foreach item a (if (member item b) (setq c (cons item c))))) c) (defun Get_SS_BlockNames ( ss / n l) (foreach o (ss->ol ss)(if (and (setq n (block-n o))(not (member n l)))(setq l (cons n l)))) l) (defun SS->OL (ss / i l)(setq i 0)(repeat (sslength ss)(setq l (cons (vlax-ename->vla-object (ssname ss i)) l) i (1+ i))) l) (defun void (x) (or (eq x nil)(and (listp x)(not (vl-consp x)))(and (eq 'STR (type x))(eq "" (vl-string-trim " \t\r\n" x))))) (defun block-n (o)(if (and (= 'vla-object (type O))(eq (vla-get-objectname O) "AcDbBlockReference")) (if (vlax-property-available-p o 'EffectiveName) (vla-Get-EffectiveName o) (vla-Get-Name o)) nil)) (defun Collection-Member (m c / r) (if (vl-catch-all-error-p (setq r (vl-catch-all-apply 'vla-item (list c m)))) nil r)) ;;; display list (plus message) (defun dplm (l m / f p d w) (and (vl-consp l) (setq l (mapcar 'vl-princ-to-string l)) (setq w (+ 5 (apply 'max (mapcar 'strlen l)))) (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ (strcat "cfl:dialog{label=\"" m "\";:list_box {key=\"lb\";" "width="(itoa w)";}ok_only;}") p)(not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d)(progn (start_list "lb") (mapcar 'add_list l)(end_list)(action_tile "accept" "(done_dialog)")(start_dialog)(unload_dialog d)(vl-file-delete f)))) ;; choose from list (cfl '("1""2""3")) (defun cfl (l / f p d r) (and (setq p (open (setq f (vl-filename-mktemp ".dcl")) "w")) (princ "cfl:dialog{label=\"Choose\";:list_box{key=\"lb\";width=40;}ok_cancel;}" p) (not (setq p (close p)))(< 0 (setq d (load_dialog f)))(new_dialog "cfl" d) (progn (start_list "lb")(mapcar 'add_list l)(end_list)(action_tile "lb" "(setq r (nth (atoi $value) l))(done_dialog 1)") (action_tile "accept" "(setq r (get_tile \"lb\"))(done_dialog 1)")(action_tile "cancel" "(setq r nil)(done_dialog 0)") (start_dialog)(unload_dialog d)(vl-file-delete f))) (cond ((= r "") nil)(r r)(t nil))) Edited Wednesday at 10:25 PM by rlx 2 Quote
X11start Posted Thursday at 06:46 AM Author Posted Thursday at 06:46 AM I created a pdf with all the steps: as expected by RLX, the lisp works perfectly! 'cbp2.lsp' can be used by those like me who use GStarCAD. Thank you very much! CBP2.pdf Quote
rlx Posted Thursday at 08:06 AM Posted Thursday at 08:06 AM Youre welcome Only tweak I would probably do is to select your basepoint at the same time when you select your objects but that should be easy to do , but its not that importand anyways. For now : paste away ... Quote
X11start Posted Thursday at 09:59 AM Author Posted Thursday at 09:59 AM Out of curiosity, since for me many of the commands you wrote are as understandable as ancient Aramaic: which are the commands that you didn't include in the latest version... and that allowed Lisp to work even on GSTARCAD? Quote
SLW210 Posted Thursday at 10:14 AM Posted Thursday at 10:14 AM What version of GstarCAD are you using? Enhanced API in GstarCAD 2024 I would think anything that runs in AutoCAD LT would work, if I have time and @rlx doesn't get back, I'll try to look at them (I am curious about this). If you could carefully list out what happened with each code in AutoCAD and GstarCAD, it would help. 1 Quote
rlx Posted Thursday at 10:37 AM Posted Thursday at 10:37 AM in essence I took out the dbx stuf like : (defun dbx_ver ( / v) (strcat "objectdbx.axdbdocument" (if (< (setq v (atoi (getvar 'acadver))) 16) "" (strcat "." (itoa v))))) (setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp)) (setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver)))) (vla-open dbx dwg) ; put all block objects in a list (setq object-list (ss->ol ss)) ; put list with objects in a safe array (setq object-safe-array (vlax-make-safearray vlax-vbobject (cons 0 (1- (length object-list))))) (vl-catch-all-apply 'vlax-safearray-fill (list object-safe-array object-list)) ; copy objects to dbx-drawing (vla-CopyObjects acDoc object-safe-array (vla-get-ModelSpace dbx)) (vl-catch-all-apply 'vla-saveas (list dbx dwg)) (vl-catch-all-apply 'vlax-release-object (list dbx)) (setq object-list nil object-safe-array nil) In lasted version I used : (defun Get_EX_Blocknames (dbDoc / fn l) (if (and (eq (type dbDoc) 'STR)(setq fn (findfile dbDoc)) (setq doc (vla-open (vla-get-documents (vlax-get-acad-object)) fn))) (progn (setq l (GetDocBlockNames doc))(vla-close doc)(vlax-release-object doc))) l) ;;; test (setq lst (GetDocBlockNames (vla-get-ActiveDocument (vlax-get-acad-object)))) (defun GetDocBlockNames ( d / b n l) (vlax-for b (vla-get-blocks d) (if (and (= :vlax-false (vla-get-isxref b)) (= :vlax-false (vla-get-islayout b)) (not (vl-string-search "*" (setq n (vla-get-name b)))))(setq l (cons n l)))) l) instead of using (vla-open dbx dwg) I now used (vla-open (vla-get-documents (vlax-get-acad-object)) fn) using vla-open means you best only use vla- commands and never ever use vla-activate until the very last end because at that point lisp focus will end there and any code left with it. Lisp can only run in one document at the time , but when using vla- commands only it is possible to open and close other drawing and stil maintain lisp focus. Maybe not beginners stuf but me too only got where I am by beg steal & borrow code from others , change things an see what happens. This all costs time but having a wife with her own hobbies or not having a social life all helps 1 Quote
SLW210 Posted Thursday at 10:44 AM Posted Thursday at 10:44 AM After a quick look on GstarCAD, DBX works, though some commands may be different from AutoCAD's. If time allows I might make an attempt to narrow down some options. Quote
X11start Posted Thursday at 12:03 PM Author Posted Thursday at 12:03 PM (edited) My version of GStarCAD is 2023 Italian Even my social life is not the most active... but in 30 years of CAD I have reached a good level of basic Lisp... but nothing more complicated GSTARCAD is excellent software ... but sometimes it has small bugs that have never been fixed: (vl-sort '("2" "1" "3" "1") '<) In Autocad: ("1" "1" "2" "3") in GStarCAD: ("1" "2" "3") Duplicate elements are removed! Edited Thursday at 12:06 PM by X11start Quote
BIGAL Posted yesterday at 12:01 AM Posted yesterday at 12:01 AM Somewhere there is a comment in the Acad help about using sort and it removes duplicates. If you use different sort method you can get around it. I have some where Bubblesort method also. (setq a '("1" "2" "1" "3" "1" "4")) (acad_strlsort a) ("1" "1" "1" "2" "3" "4") (defun BubbleSort (lstItems / blnFlag item1 item2 lstItems2) (setq item1 (car lstItems)) (foreach item2 (cdr lstItems) (if (<= item1 item2) (setq lstItems2 (cons item1 lstItems2) item1 item2 ) (setq lstItems2 (cons item2 lstItems2) blnFlag T ) ) ) (if blnFlag (BubbleSort (reverse (cons item1 lstItems2))) (reverse (cons item1 lstItems2)) ) ) (setq a '("01" "122" "A34" "3" "1" "54b" "27")) (bubblesort a) ("01" "1" "122" "27" "3" "54b" "A34") Quote
X11start Posted 13 hours ago Author Posted 13 hours ago Thanks BIGAL: I overcame the problem by using VL-SORT-I: (setq lst '("2" "1" "3" "1")) (mapcar '(lambda (x) (nth x lst))(vl-sort-i lst '<)) the result is: ("1" "1" "2" "3") For completeness, I also refer to a post where I was looking for a way to arrange elements according to various criteria. HERE ... but the VL-SORT mentioned in this post was only to illustrate that GStarCAD sometimes behaves strangely, or even just differently from AutoCAD. Thank you anyway for your interest: it’s always great when experienced users take the time to understand other people's problems! Quote
mhupp Posted 11 hours ago Posted 11 hours ago (edited) Just a side note sort has some other funky quirks with "sorting" As shown in @BIGAL's example of (bubblesort a) were 127 is before 27 and 3 Even windows explorer does this also. I don't know what kinda of strings your working with but maybe consider using fixed numbering showing them in the correct order ("001" "001" "003" "027" "122" "54b" "A34") Tho if these are block names that is no good because 001 <> 1. Maybe convert your list into dotted pairs this would keep all unique values and a running count (defun C:foo ( / test lst item) (setq test '("1" "2" "3" "3" "1" "2" "2" "1" "3" "1" "3" "1")) (setq lst '()) ; initialize empty list (foreach str test (setq item (assoc str lst)) ; check if str is in lst (if item (setq lst (subst (cons str (+ (cdr item) 1)) item lst)) ; update count (setq lst (cons (cons str 1) lst)) ; add new string with count 1 ) ) (setq lst (vl-sort lst '(lambda (x y) (< (car x) (car y))))) ;sorts lst by car of dotted pair (princ "\nCounts:") (foreach itm lst (princ (strcat "\n" (car itm) ": " (itoa (cdr itm)))) ) (princ) ) Edited 10 hours ago by mhupp Quote
rlx Posted 1 hour ago Posted 1 hour ago Since we're all going off topic (thanks a lot Bigal) , might as well join the band. Added the 'check before paste' lisp to my toolbar. Not sure if I'm ever gonna use it but that wasn't the point, was working on a way to make it a little more easier for myself to update the toolbars for my colleagues (the old last century toolbars , you oldies know what I mean) so lazy as I am , created a button for that too. It hasn't been field tested though so it may or may not work at all... New for me was the help part. Never used html in my life before and also read-write stream only used a couple of times (to create a few .bmp files for the toolbar by means of lisp , look for the Party button) So lets party yeah! euh ...the button I mean , what I mean by that , read the .... manual (oh just press the darn help button) Easy_Toolbar_Creator.lsp 1 Quote
