Hi again.
This may also happen to others: sometimes I have two polylines and I need to get something like a common parallel to both. A sort of hybrid parallel from the original two.
Is it possible that this topic has been discussed in the history of this forum and there is a LISP to solve this problem?
Thanks in advance.
Posting a drawing would help to be more clear with what your asking for. but maybe this is what your looking for. PAV
Edited by mhupp
This?
Perhaps the most appropriate description is to obtain the axis between 2 irregular polylines
Edited by PGia
Look into this post for ideas:
@pkenewell Thanks for help.
I downloaded the latest code from link and loaded it, but it doesn't seem to do anything.
I probably don't understand how it works.
1 hour ago, PGia said:
I tried it. But it only works sometimes. And if the polylines' first point coincides with the last, it doesn't work.
Is it possible that I'm doing something wrong?
The code does not work correctly with polylines that have a large number of segments.
Example1.dwg
Thanks for help.
 The "MC" command by roy437 works for me on your example drawing. You have to set the point resolution (prompt for "Specify Length for arc(ds)") to improve the results. I used 0.1 for pretty good results.
Edited by pkenewell
@pkenewell Thank you very much.
I finally got it working.
In my case, I set the "length of arcs" to 1. And it worked. But I think the resulting axis isn't very geometrically rigorous. I've attached an example image:
-The polyline created by the command is shown in green.
-The correct geometry of the axis is shown in dashed red.
I think there should be a more geometrically rigorous solution in some older Lisp.
Is it possible?
Does anyone know of one?
