Nikon Posted yesterday at 06:40 PM Posted yesterday at 06:40 PM (edited) There are several fields with 1 decimal place. Is there a way to convert selected fields with 1 decimal place into fields with 2 decimal places without losing the connection of fields with objects? The field is 1 decimal place %<\AcExpr (3.1416*%<\_FldPtr 1317270971888>%^2/4*0.0785*%<\_FldPtr 1317270971632>%*%<\_FldPtr 1317270971472>%/10000) \f "%lu2%pr1">% The field is 2 decimal places %<\AcExpr (3.1416*%<\_FldPtr 1317157078864>%^2/4*0.0785*%<\_FldPtr 1317157078096>%/10000) \f "%lu2%pr2">% fields.dwg Edited 8 hours ago by Nikon Quote
Steven P Posted 23 hours ago Posted 23 hours ago "pr2" is precision - here 2 places, "pr1" at the end of the first expression is 1 decimal place 1 Quote
Nikon Posted 14 hours ago Author Posted 14 hours ago (edited) 15 hours ago, Steven P said: "pr2" is precision - here 2 places, "pr1" at the end of the first expression is 1 decimal place I have dozens of fields that need to be changed the precision. It will take a long time to edit each field... Edited 7 hours ago by Nikon Quote
BIGAL Posted 13 hours ago Posted 13 hours ago (edited) If you can identify where the field strings are then you could update them, you can look for say "AcExpr" in the string then replace pr1. Maybe use Bedit and Attsync to update blocks. Similar for Mtext. Â So where are they ? Provide a sample dwg, You should be able to do something by now look at (Vlax-get obj 'textstring) Edited 13 hours ago by BIGAL Quote
Nikon Posted 12 hours ago Author Posted 12 hours ago 23 minutes ago, BIGAL said: So where are they ? Provide a sample dwg, The fields are in the text, not in the block. The sample fields.dwg is attached in the first post. The problem is that you need to change the accuracy of several fields at the same time. Quote
Tsuky Posted 9 hours ago Posted 9 hours ago You can try this. (vl-load-com) (defun c:change_prec ( / ss AcDoc Space n ename Obj value_string nbs tmp_nbs) (princ "\nSelect MText.") (while (null (setq ss (ssget (list '(0 . "*TEXT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nAren't MText or Text!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) Obj (vlax-ename->vla-object ename) ) (setq value_string (vla-FieldCode Obj) nbs 0) (cond ((eq (substr (vla-FieldCode Obj) 1 3) "%<\\") (while nbs (if (setq nbs (vl-string-search "%pr2" value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst "%pr1" "%pr2" value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put Obj 'TextString value_string) ) ) ) (vla-endundomark AcDoc) (prin1) ) Â 2 Quote
Nikon Posted 9 hours ago Author Posted 9 hours ago (edited) 8 hours ago, Tsuky said: You can try this. (vl-load-com) (defun c:change_prec @Tsuky thank you very much, your code changes the precision of the fields from 2 to 1. I replaced 2 lines in the code to change the precision from 1 to 2. (if (setq nbs (vl-string-search "%pr2" value_string (setq tmp_nbs nbs)))       (setq        value_string (vl-string-subst "%pr1" "%pr2" value_string tmp_nbs) * * * *  * * * *  * * * *  * * * *  * * * *  * * * *  * * * *  * * * * * * * *  * * * *  * (if (setq nbs (vl-string-search "%pr1" value_string (setq tmp_nbs nbs)))       (setq        value_string (vl-string-subst "%pr2" "%pr1" value_string tmp_nbs) * * * *  * * * *  * * * *  * * * * * * * *  * * * *  * * * *  * * * * * * * *  * * * *  * You've been very helpful!   Edited 1 hour ago by Nikon 1 Quote
Nikon Posted 7 hours ago Author Posted 7 hours ago 2 hours ago, Tsuky said: You can try this. (vl-load-com) (defun c:change_prec I have made several versions of the change_prec.lsp code. Maybe it will be useful to someone. Changing the precision of several fields =========================================================== change_prec_1-2.lsp === changing the precision of the fields from 1 to 2 change_prec_1-3.lsp === changing the precision of the fields from 1 to 3 change_prec_2-1.lsp === changing the precision of the fields from 2 to 1 change_prec_2-3.lsp === changing the precision of the fields from 2 to 3 change_prec_3-1.lsp === changing the precision of the fields from 3 to 1 change_prec_3-2.lsp === changing the precision of the fields from 3 to 2 =========================================================== change_prec_fields.lsp 1 Quote
mhupp Posted 6 hours ago Posted 6 hours ago (edited) Added a little on the front end to wrap it all in one command with user input options. Should display something like this  Change_Prec or CP Enter "C" for Custom Values Choose Percision From:To : [1:2 1:3 2:1 2:3 3:1 3:2]: 3:2 Changing Select MText Precision From [3] to [2] ... Change_Prec or CP Enter "C" for Custom Values Choose Percision From:To : [1:2 1:3 2:1 2:3 3:1 3:2]: C Existing Precision: 1 Precision Change to: 4 Changing Select MText Precision From [1] to [4] ... Change_Prec 2 1 Changing Select MText Precision From [2] to [1] ...  -Edit Updated it so you can just type "Change_Prec 3 2" and skip all that and just start asking you to make a selection.    change_prec_fields_update.lsp Edited 4 hours ago by mhupp 1 Quote
Nikon Posted 5 hours ago Author Posted 5 hours ago (edited) 2 hours ago, mhupp said: Added a little on the front end to wrap it all in one command with user input options. Should display something like this Thanks, that's a good idea, but this code doesn't work for me. Edited 4 hours ago by Nikon Quote
mhupp Posted 5 hours ago Posted 5 hours ago (edited) I'll have to debug it when i get home just typed it up in note pad.  -Edit Well if i took two seconds to look at the code. was using integers and needs to be strings. because Tusky is calling vl-string-subst. if its still bugged ill fix it tonight. Edited 5 hours ago by mhupp 1 Quote
Tsuky Posted 32 minutes ago Posted 32 minutes ago With (initget) and (getkword) for choice precision... (vl-load-com) (defun c:change_prec ( / ss AcDoc Space ksource ktarget n ename Obj value_string nbs tmp_nbs) (princ "\nSelect MText.") (while (null (setq ss (ssget (list '(0 . "*TEXT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nAren't MText or Text!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (initget 1 "0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16") (setq ksource (getkword "\nPrecision of source number [0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15/16]?: ")) (initget 1 "0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16") (setq ktarget (getkword "\nPrecision of target number [0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15/16]?: ")) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) Obj (vlax-ename->vla-object ename) ) (setq value_string (vla-FieldCode Obj) nbs 0) (cond ((eq (substr (vla-FieldCode Obj) 1 3) "%<\\") (while nbs (if (setq nbs (vl-string-search (strcat "%pr" ksource) value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst (strcat "%pr" ktarget) (strcat "%pr" ksource) value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put Obj 'TextString value_string) ) ) ) (vla-endundomark AcDoc) (prin1) ) Â 1 Quote
Nikon Posted 13 minutes ago Author Posted 13 minutes ago (edited) 18 minutes ago, Tsuky said: With (initget) and (getkword) for choice precision... (vl-load-com) (defun c:change_prec ( / ss AcDoc Space ksource ktarget n ename Obj value_string nbs tmp_nbs) For some reason, the code only works in Text. When selecting MText, the precision does not change... Is it possible to assign the same precision or current precision to fields with different precision? Â Edited 13 minutes ago by Nikon Quote
