Please see attached
I have a Block and mText Field linked to the same Boundary.
currently the mText works great but would like to have the option of amending the precision within the block also.
Field Precision.dwg
Ok as the block supplied has a hard coded ID of an object in the field statement, then this block is somehow being made for every area that is labelled. With a change to the objectId relevant to each area chosen.
So are you getting this from some one else ? Or you just have a make a new block program labelling the area ? If you have a program then hopefully its just a simple add a do you want 0 1 2 or 3 for precision.
This is fieldcode for the mtext, the dynamic block adds an extra hurdle.
"\\A1;{\\H1.42857x;%<\\AcObjProp Object(%<\\_ObjId 1668905712>%).Area \\f \"%lu2%pr3\">%m\\H0.7x;\\S2^;\\H1.42857x; \\P\\H1x;mText }"
If you want 2 decs then change the pr3 to pr2.
Edited by BIGAL
@CamDuy gave it a try it appears to only look for a text object the OP wants an attribute in a block also to be updated.
those are attribute references of a block. Since vla-fieldcode only works on Text and mtext i used Lee Macs fieldcode instead
https://www.lee-mac.com/fieldcode.html
It should work on Blocks Attributereferences as well now.
(defun c:change_prec (/ *error* acdoc undo-mark ss target index ename obj att field-string revised-string)
  (defun *error* (msg)
    (if undo-mark
        (vl-catch-all-apply 'vla-EndUndoMark (list acdoc))
        (setq undo-mark nil)
    (if (and msg
          (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (prompt "\nSelect text, MText, or attributed blocks: ")
  (while (null (setq ss (ssget '((0 . "TEXT,MTEXT,INSERT")))))
    (prompt "\nNo valid text, MText, or blocks selected.")
  (initget 1 "0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Current")
  (setq target (getkword "\nTarget precision [0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15/16/Current]: "))
  (vla-StartUndoMark acdoc)
  (setq undo-mark T)
  (repeat (setq index (sslength ss))
    (setq index (1- index)
          ename (ssname ss index)
          obj   (vlax-ename->vla-object ename)
    (cond
      ;; Text or MText
      ((wcmatch (vla-get-ObjectName obj) "AcDbText,AcDbMText")
        (setq field-string (vla-FieldCode obj))
        (if (and field-string
            (setq revised-string (replacePrecision field-string target))
          (vla-put-TextString obj revised-string)
      ;; Block reference with editable attributes
      ((vlax-method-applicable-p obj 'GetAttributes)
        (foreach att (vlax-invoke obj 'GetAttributes)
          (setq field-string (LM:fieldcode (vlax-vla-object->ename att)))
            (vla-put-TextString att revised-string)
  (vla-EndUndoMark acdoc)
  (vla-Regen acdoc acActiveViewport)
(defun replacePrecision (fieldStr target / nbs prec_source return)
  (setq nbs 0)
  (cond
      ((vl-string-search "%<\\" fieldStr nbs)
        (while nbs
          (if (setq nbs (vl-string-search "%pr" fieldStr (setq tmp_nbs nbs)))
            (setq
              prec_source (itoa (atoi (substr fieldStr (+ nbs 4) 2)))
              fieldStr
              (vl-string-subst
                (if (eq target "Current")
                  (strcat "%pr" (itoa (getvar "LUPREC")))
                  (strcat "%pr" target)
                (strcat "%pr" prec_source)
                fieldStr
                tmp_nbs
              nbs (1+ nbs)
        (setq return fieldStr)
  return
;; Field Code  -  Lee Mac
;; Returns the field expression associated with an entity
(defun LM:fieldcode ( ent / replacefield replaceobject fieldstring enx )
    (defun replacefield ( str enx / ent fld pos )
        (if (setq pos (vl-string-search "\\_FldIdx" (setq str (replaceobject str enx))))
                (setq ent (assoc 360 enx)
                      fld (entget (cdr ent))
                (strcat
                    (substr str 1 pos)
                    (replacefield (fieldstring fld) fld)
                    (replacefield (substr str (1+ (vl-string-search ">%" str pos))) (cdr (member ent enx)))
            str
    (defun replaceobject ( str enx / ent pos )
        (if (setq pos (vl-string-search "ObjIdx" str))
            (strcat
                (substr str 1 (+ pos 5)) " "
                (LM:ObjectID (vlax-ename->vla-object (cdr (setq ent (assoc 331 enx)))))
                (replaceobject (substr str (1+ (vl-string-search ">%" str pos))) (cdr (member ent enx)))
            str
    (defun fieldstring ( enx / itm )
        (if (setq itm (assoc 3 enx))
            (strcat (cdr itm) (fieldstring (cdr (member itm enx))))
            (cond ((cdr (assoc 2 enx))) (""))
    (if (and (wcmatch  (cdr (assoc 0 (setq enx (entget ent)))) "TEXT,MTEXT,ATTRIB,MULTILEADER,*DIMENSION")
             (setq enx (cdr (assoc 360 enx)))
             (setq enx (dictsearch enx "ACAD_FIELD"))
             (setq enx (dictsearch (cdr (assoc -1 enx)) "TEXT"))
        (replacefield (fieldstring enx) enx)
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:ObjectID ( obj )
    (eval
        (list 'defun 'LM:ObjectID '( obj )
            (if
                (and
                    (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
                    (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
                (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
               '(itoa (vla-get-objectid obj))
    (LM:ObjectID obj)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
  • Like 2
Just tested it this morning and working perfectly!
Can't thankyou enough for that. Awesome.
Following on from EnM4st3r Code.
I have added a function to create the "%pr" if none exists.
I had this happen when the Field is created using "Current Precision" as the string does not contain the required %pr by default.
(defun c:ChangePrec (/ *error* acdoc undo-mark ss target index ename obj att field-string revised-string)
    (if undo-mark
    (if (and msg
  (prompt "\nSelect text, MText, or Attributed Blocks: ")
  (initget 1 "0 1 2 3 4 5 6 7 Current")
  (setq target (getkword "\nTarget precision [0/1/2/3/4/5/6/7/Current]: "))
  (setq undo-mark T)
    (cond
      ;; Text or MText
                          / nbs tmp_nbs prec return
                            fmtStart fmtEnd fmtString newPrec)
    (setq newPrec
        (strcat
            "%pr"
            (if (= target "Current")
                target
    ;; Existing precision -> replace it
    (if (setq nbs (vl-string-search "%pr" fieldStr))
            (while nbs
                (setq tmp_nbs nbs
                      prec (itoa (atoi (substr fieldStr (+ nbs 4) 2)))
                      fieldStr
                        (vl-string-subst
                            newPrec
                            (strcat "%pr" prec)
                            fieldStr
                            tmp_nbs
                      nbs (vl-string-search "%pr" fieldStr (+ tmp_nbs (strlen newPrec)))
        ;; No %pr found
            ;; Existing format string?
            (if (setq fmtStart (vl-string-search "\\f \"" fieldStr))
                ;; Append %pr to existing format string
                    (setq fmtStart (+ fmtStart 4)
                          fmtEnd (vl-string-search "\"" fieldStr fmtStart)
                          fmtString (substr fieldStr (1+ fmtStart)
                                            (- fmtEnd fmtStart))
                    (setq return
                        (strcat
                            (substr fieldStr 1 fmtStart)
                            fmtString
                            newPrec
                            (substr fieldStr (1+ fmtEnd))
                ;; No format string at all -> create one
                (if (setq fmtEnd (vl-string-search ">%" fieldStr))
                    (setq return
                        (strcat
                            (substr fieldStr 1 (1- fmtEnd))
                            " \\f \""
                            newPrec
    return
                (strcat
                    (substr str 1 pos)
            str
            (strcat
            str
    (eval
            (if
                (and
    (LM:ObjectID obj)
(defun LM:acdoc nil
    (LM:acdoc)
  • Thanks 1
