I don't believe I posted my Import multiple PDF pages as AutoCAD objects LISP.
It does most of what I need, so I doubt if I'll spend any more time on it.
;;; Imports indicated page(s), converts to DWG entities, then arranges them spaced along +X.      |
;;; ImPDF.lsp        |
;;; By SLW210 (a.k.a. Steve Wilson)                                                               |
;;; Requires: AutoCAD 2024 +        |
(defun c:ImPDF (/	 pdfPath  pgStart  pgEnd    pg	     insPt
		gap	 doc	  ms	   layerColor	     bgColor
		layerName	  blk
  (vl-load-com)
  ;; Detect background color
  (setq bgColor (getvar "BACKGROUNDCOLOR")) ; 0=black, 7=white
  (setq	layerColor
	 (if (= bgColor 0)
	   7
	   0
  )					; white on black, black on white
  ;; Select PDF file
  (setq pdfPath (getfiled "Select PDF file to import" "" "pdf" 8))
  (if (not pdfPath)
    (exit)
  ;; Page range
  (setq pgStart (getint "\nStart page <1>: "))
  (if (not pgStart)
    (setq pgStart 1)
  (setq pgEnd (getint "\nEnd page <same>: "))
  (if (not pgEnd)
    (setq pgEnd pgStart)
  ;; Starting insertion point
  (setq insPt (getpoint "\nInsertion point: "))
  (if (not insPt)
    (setq insPt '(0 0 0))
  ;; Gap between pages
  (setq gap (getreal "\nGap between pages <5.0>: "))
  (if (not gap)
    (setq gap 5.0)
  ;; Get AutoCAD document
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  ;; Set all entities inside block definition to layer + color
  (defun set-block-contents-color (blkRef layer color / blkDef)
    (setq blkDef (vla-item (vla-get-Blocks doc) (vla-get-Name blkRef)))
    (vlax-for ent blkDef
      (vl-catch-all-apply 'vla-put-layer (list ent layer))
      (vl-catch-all-apply 'vla-put-color (list ent color))
  ;; Loop through pages
  (setq pg pgStart)
  (while (<= pg pgEnd)
    (princ (strcat "\nImporting page " (itoa pg) "..."))
    ;; Attach PDF underlay
    (command "_-PDFATTACH" pdfPath (itoa pg) insPt 1.0 0.0)
    (setq u (entlast))
    ;; underlay reference
    ;; Import to geometry (All, then detach)
    (command "_PDFIMPORT" u "All" "D")
    ;; The imported block reference is the last entity
    (setq blk (entlast))
    (if	blk
	;; Create layer for this page
	(setq layerName (strcat "PDF_Page_" (itoa pg)))
	(if (not (tblsearch "layer" layerName))
	  (vl-catch-all-apply
	    'vla-Add
	    (list (vla-get-Layers doc) layerName)
	;; Move block reference to layer
	(vl-catch-all-apply
	  'vla-put-layer
	  (list (vlax-ename->vla-object blk) layerName)
	;; Set nested geometry inside block
	(set-block-contents-color
	  layerName
	  layerColor
	;; Compute block width for next insertion point
	(setq minX 1e20
	      maxX -1e20
	(vl-catch-all-apply
	  'vla-getboundingbox
	  (list (vlax-ename->vla-object blk) 'pmin 'pmax)
	(setq pmin (vlax-safearray->list pmin))
	(setq pmax (vlax-safearray->list pmax))
	(setq width (- (car pmax) (car pmin)))
	(if (<= width 0.0)
	  (setq width 100.0)
	;; Update insertion point for next page
	(setq insPt (list (+ (car insPt) width gap) (cadr insPt) 0))
    ;; Next page
    (setq pg (1+ pg))
  (command "_ZOOM" "_E")
  (princ
    "\nAll pages imported successfully."
With RLX's revision.
;;; ImPDF_0.2-RLX.lsp        |
;;; Requires: AutoCAD 2017 + (for PDFIMPORT)                                                      |
;;; Revision by RLX
		layerName	  blk
  (vl-load-com)
  (setq	layerColor
	 (if (= bgColor 0)
	   7
	   0
  ;; Select PDF file
  (if (not pdfPath)
    (exit)
  ;; Page range
  (if (not pgStart)
    (setq pgStart 1)
  (if (not pgEnd)
  (if (not insPt)
  (if (not gap)
    (setq gap 5.0)
    (if (and blkRef (vlax-method-applicable-p blkRef 'Name))
  (setq pg pgStart)
    (setq u (entlast))
    (if	blk
	  (vl-catch-all-apply
	    'vla-Add
	(vl-catch-all-apply
	  'vla-put-layer
	  layerName
	  layerColor
	(setq minX 1e20
	      maxX -1e20
	(vl-catch-all-apply
	  'vla-getboundingbox
	(if (<= width 0.0)
	  (setq width 100.0)
    ;; Next page
    (setq pg (1+ pg))
  (princ
Edited by SLW210
Update Code per RLX
  • Like 2
  • Thanks 1
Great! Thanx! It did gave me an error after the first page so I changed one of your subs a little.
added this line : (and blkRef (vlax-method-applicable-p blkRef 'Name))
  • Thanks 1
@SLW210 have a look at this by Lee-mac may be useful. I did have problems may be my Bricscad or pdf I am using.
https://www.theswamp.org/index.php?PHPSESSID=a86a2d2e880b6079f1d3aee842f41d9d&topic=39001.msg441632#msg441632
This may also be useful once you know count.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq vals (AH:getvalsm  (list "Enter Pdf range" "Enter start Pdf number" 6 4 "1" "Enter end Pdf number" 6 4 (RTOS COUNT 2 0))))
("1" "22")
Edited by BIGAL
I only used it twice and it worked fine on those, latest one was 8 sheets, the first time was a while back not sure how many sheets.
IIRC, it may only work on AutoCAD 2024 or newer in this version. Tested on AutoCAD 2026. I did this several months ago and just needed it again yesterday.
So @rlx's addition may be needed for older.
@BIGAL I thought about do a count, but I don't need it.
I'll try to find time to research BricsCAD use.
I was working on creating a Layout tab for each sheet, I might get back to it later, busy with paid work right now.
Only other update I plan is maybe get more than one PDF, but that will much further down the line.
maybe its just a matter of name vs effective block name issue , haven't tested that. But I like the routine and maybe gonna extend it a little with above suggestions if I run into a project that could benefit from this. Did find a program , I think it's called able2extact or something , that also has OCR built in but it will set you back around two hundred dollars , lifte time subscription.
I added the RLX change, I'll check it out when I get back to work.
RLX's doesn't change the  color according to background. I use a black background and some objects are the color of the background. (This might be able to be adjusted in the PDFIMPORT options.)
I tried some different PDF's and the original works fine in AutoCAD 2026 plus everything is white on black background, I need to try again with white background, but that also worked previously on the original, I might try 2025 later today if I get the time.
IIRC, Adobe Acrobat, Bluebeam, and probably others have OCR options, but I usually don't bother converting text unless necessary, then I just manually use the one in AutoCAD, occasionally I have used the Acrobat OCR with mixed results.
Of coarse, this would be much simpler if we just made the contractors give us the actual AutoCAD files instead of PDFs, me doing such a good job with the PDFs they don't seem to want to put forth the effort. I have had them send .dwg when they didn't convert well. Keeps me employed I guess.
Just a comment did find an answer to the get number of pages in a pdf. Found a great link.
https://www.robvanderwoude.com/pdftips.php
I tested using windows cmd may need a bat maybe use (startapp.
Ghostscript
d:\gs\gs10.02.1\bin\gswin64c.exe -q -dNODISPLAY -dNOSAFER --permit-file-read="D:\Acadtemp\vba-tutorial-for-autocad-pdf-1.pdf" -c "("D:\\Acadtemp\\vba-tutorial-for-autocad-pdf-1.pdf") (r) file runpdfbegin pdfpagecount = quit" >"D:\acadtemp\pagenum.txt"
Exiftool
exiftool.exe -PageCount D:\Acadtemp\vba-tutorial-for-autocad-pdf-1.pdf
Winodws cmd
TYPE D:\Acadtemp\vba-tutorial-for-autocad-pdf-1.pdf 2>NUL | FINDSTR.EXE /R /C:"/Type[	 ]*/Page" 2>NUL | FIND.EXE /V "/Pages" | FIND.EXE /C "/Page" >D:\acadtemp\pagenum.txt
Tested using windows method with a bat file.
(setq shell (vla-getinterfaceobject (vlax-get-acad-object) "shell.application"))
(vlax-invoke-method shell 'ShellExecute "D:\\acadtemp\\test.bat")
Edited by BIGAL
Adding number of pages is more work than I have time to spare right now.
I am swamped until the first of the year and probably into January at work, plus the holidays. I might work on some things over the Holidays at home if time allows.
Lots of options to retrieve... How to write shell script for finding number of pages in PDF? - Stack Overflow
A quick look on the BricsCAD issue, seems it is more limited in calling PDFATTACH and PDFIMPORT with the options, though main issue could be the background detection in my code.
