SLW210 Posted Friday at 03:35 PM Posted Friday at 03:35 PM (edited) I don't believe I posted my Import multiple PDF pages as AutoCAD objects LISP. It does most of what I need, so I doubt if I'll spend any more time on it. ;;; Imports indicated page(s), converts to DWG entities, then arranges them spaced along +X. | ;;;-----------------------------------------------------------------------------------------------| ;;; ImPDF.lsp | ;;; | ;;; By SLW210 (a.k.a. Steve Wilson) | ;;; | ;;; Requires: AutoCAD 2017 + (for PDFIMPORT) | ;;;-----------------------------------------------------------------------------------------------| (defun c:ImPDF (/ pdfPath pgStart pgEnd pg insPt gap doc ms layerColor bgColor layerName blk ) (vl-load-com) ;; Detect background color (setq bgColor (getvar "BACKGROUNDCOLOR")) ; 0=black, 7=white (setq layerColor (if (= bgColor 0) 7 0 ) ) ; white on black, black on white ;; Select PDF file (setq pdfPath (getfiled "Select PDF file to import" "" "pdf" 8)) (if (not pdfPath) (exit) ) ;; Page range (setq pgStart (getint "\nStart page <1>: ")) (if (not pgStart) (setq pgStart 1) ) (setq pgEnd (getint "\nEnd page <same>: ")) (if (not pgEnd) (setq pgEnd pgStart) ) ;; Starting insertion point (setq insPt (getpoint "\nInsertion point: ")) (if (not insPt) (setq insPt '(0 0 0)) ) ;; Gap between pages (setq gap (getreal "\nGap between pages <5.0>: ")) (if (not gap) (setq gap 5.0) ) ;; Get AutoCAD document (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ;; Set all entities inside block definition to layer + color (defun set-block-contents-color (blkRef layer color / blkDef) (if (and blkRef (vlax-method-applicable-p blkRef 'Name)) (progn (setq blkDef (vla-item (vla-get-Blocks doc) (vla-get-Name blkRef))) (vlax-for ent blkDef (vl-catch-all-apply 'vla-put-layer (list ent layer)) (vl-catch-all-apply 'vla-put-color (list ent color)) ) ) ) ) ;; Loop through pages (setq pg pgStart) (while (<= pg pgEnd) (princ (strcat "\nImporting page " (itoa pg) "...")) ;; Attach PDF underlay (command "_-PDFATTACH" pdfPath (itoa pg) insPt 1.0 0.0) (setq u (entlast)) ;; underlay reference ;; Import to geometry (All, then detach) (command "_PDFIMPORT" u "All" "D") ;; The imported block reference is the last entity (setq blk (entlast)) (if blk (progn ;; Create layer for this page (setq layerName (strcat "PDF_Page_" (itoa pg))) (if (not (tblsearch "layer" layerName)) (vl-catch-all-apply 'vla-Add (list (vla-get-Layers doc) layerName) ) ) ;; Move block reference to layer (vl-catch-all-apply 'vla-put-layer (list (vlax-ename->vla-object blk) layerName) ) ;; Set nested geometry inside block (set-block-contents-color (vlax-ename->vla-object blk) layerName layerColor ) ;; Compute block width for next insertion point (setq minX 1e20 maxX -1e20 ) (vl-catch-all-apply 'vla-getboundingbox (list (vlax-ename->vla-object blk) 'pmin 'pmax) ) (setq pmin (vlax-safearray->list pmin)) (setq pmax (vlax-safearray->list pmax)) (setq width (- (car pmax) (car pmin))) (if (<= width 0.0) (setq width 100.0) ) ;; Update insertion point for next page (setq insPt (list (+ (car insPt) width gap) (cadr insPt) 0)) ) ) ;; Next page (setq pg (1+ pg)) ) (command "_ZOOM" "_E") (princ "\nAll pages imported successfully." ) (princ) ) Edited 8 hours ago by SLW210 Update Code per RLX 2 1 Quote
rlx Posted Friday at 04:58 PM Posted Friday at 04:58 PM Great! Thanx! It did gave me an error after the first page so I changed one of your subs a little. added this line : (and blkRef (vlax-method-applicable-p blkRef 'Name)) (defun set-block-contents-color (blkRef layer color / blkDef) (if (and blkRef (vlax-method-applicable-p blkRef 'Name)) (progn (setq blkDef (vla-item (vla-get-Blocks doc) (vla-get-Name blkRef))) (vlax-for ent blkDef (vl-catch-all-apply 'vla-put-layer (list ent layer)) (vl-catch-all-apply 'vla-put-color (list ent color)) ) ) ) ) 1 1 Quote
BIGAL Posted yesterday at 12:01 AM Posted yesterday at 12:01 AM (edited) @SLW210 have a look at this by Lee-mac may be useful. I did have problems may be my Bricscad or pdf I am using. https://www.theswamp.org/index.php?PHPSESSID=a86a2d2e880b6079f1d3aee842f41d9d&topic=39001.msg441632#msg441632 This may also be useful once you know count. (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq vals (AH:getvalsm (list "Enter Pdf range" "Enter start Pdf number" 6 4 "1" "Enter end Pdf number" 6 4 (RTOS COUNT 2 0)))) ("1" "22") Edited yesterday at 12:04 AM by BIGAL 1 Quote
SLW210 Posted yesterday at 11:35 AM Author Posted yesterday at 11:35 AM I only used it twice and it worked fine on those, latest one was 8 sheets, the first time was a while back not sure how many sheets. IIRC, it may only work on AutoCAD 2024 or newer in this version. Tested on AutoCAD 2026. I did this several months ago and just needed it again yesterday. So @rlx's addition may be needed for older. @BIGAL I thought about do a count, but I don't need it. I'll try to find time to research BricsCAD use. I was working on creating a Layout tab for each sheet, I might get back to it later, busy with paid work right now. Only other update I plan is maybe get more than one PDF, but that will much further down the line. Quote
rlx Posted yesterday at 12:26 PM Posted yesterday at 12:26 PM maybe its just a matter of name vs effective block name issue , haven't tested that. But I like the routine and maybe gonna extend it a little with above suggestions if I run into a project that could benefit from this. Did find a program , I think it's called able2extact or something , that also has OCR built in but it will set you back around two hundred dollars , lifte time subscription. 1 Quote
SLW210 Posted 8 hours ago Author Posted 8 hours ago I added the RLX change, I'll check it out when I get back to work. Quote
