Alright folks I recently got a 3D printer and I want to make some custom number plates for my buddies and my boys 4 wheelers. I have a pretty good start but when I type TXTEXP to raise up the numbers and letters the numbers just go way off screen and get real big. Any ideas?
"Why Use TXTEXP?
3D Extrusion: Converts text into line/polyline paths that you can use the EXTRUDE command on."
So to use extrude you must have closed shapes it can take a few minutes to properly close the exploded text. When using extrude you should set a height that you want.
Can you post a .dwg?
You might give the FREE Autodesk TinkerCAD, I barley have looked at it lately, but IIRC it does a great job with 3D Text creation.
But, like you I tend to use AutoCAD and Blender to make objects for the 3D Printer.
What 3D printer do you have?
I just recalled, there used to be an APP at the Autodesk APP store, but no longer there, works on older AutoCAD, but it is also posted here at CADTutor and the Swamp.
I use Bambu Labs and it comes with Bambu Studio which has a 3D Text that is very easy, I can do a custom name plate with text directly on the machine.
