On 6/26/2026 at 10:29 PM, BIGAL said:
Need some more clarification, you ask for multi line to be different colors, but you have table that are multi row, not Multi line cells. That is a big difference. So if you just want tables with a heading and one row to be red, then any others with header and rows greater than 2 will be heading Red line rest green 87 lines. That can be done.
I think need to go back a step and work on the table creation in your other post as you pick boreholes there is no reason why the colors can not be set then. So will have a go at the other post, making single table for multiple boreholes much easier than trying to place individual tables for each borehole.
Will post something for you to say yes that is ok.
I did ask about the source data where is the say Excel or csv that has the values that are being used in your tables, you have supplied a half answer.
Hi,
I extracted the results from PDF files, and it’s very tedious and time-consuming work. I have several lines in my cells, and each line should be a different color.
Have you written a program for this before?
Edited by MSHR
Post the extracted data we can not help unless we have something we can touch. The correct way to approach this is to match the borehole label with its corresponding attribute data. I did this for a client and we are talking hundreds of objects like your boreholes, so have something maybe already done.
The simplest way is make the tables from the data.
Hi, This my excle file saomle,
I sent dwg file before.
sample.xlsx
Maybe its a language problem.
Question 1  where are you getting the dwg from ?
Question 2 why are you converting a pdf ?
Question 3 can you not go back to who made the pdf and ask for the data say a CSV file
The Excel means nothing to me
I may have to give up without source data can not really help.
