BIGAL Posted 7 hours ago Posted 7 hours ago @aridzv not sure why your not using a custom Pop menu, Toolbar or Ribbon, then you can demand load any lisp no need to preload lisps. Yes one of my custom POP menus has 130 lisps behind it. I used to run 3 custom menu's. Yes a Startuplisp as well. I have a Word doc "How to make a pop menu"How to make POP menu.docx Part 2 I have a install lisp it uses a zip file of all relevant files and it is un zipped via lisp to correct directory, support paths added, new menu's added. If you look into Regedit you can find the appload list in the registry and change it. Quote
VicoWang Posted 6 hours ago Author Posted 6 hours ago @aridzv @BIGAL Thank you both for sharing your workflows! Just like drafting in CAD where there are a dozen ways to achieve the same geometric result, managing LISP environments has evolved its own art forms over the decades. Using an Excel sheet to drive autoload lines, or writing custom Install.lsp scripts to unpack ZIPs and inject into the Windows Registry—these are absolute classics. In fact, these exact methodologies are the spiritual predecessors to modern package management. VedaCAD is simply a modernized, "npm-style" iteration of the exact same goals you both achieved manually. By the way, I noticed from your profile signatures that both of you are running BricsCAD Pro. Since VedaCAD is currently compiled as a native AutoCAD .vlx container, you wouldn't be able to load or test the attachment anyway! But I genuinely appreciate you diving into the conceptual discussion with me. @aridzv, regarding your note on open-source: I completely respect your stance. For actual drafting tools, geometry calculators, or productivity scripts, open-source is the absolute gold standard of this forum. However, VedaCAD is not a drafting tool; it is the client-side node of a commercial B2B SaaS infrastructure. Under the hood, it contains hand-rolled JSON parsers, cryptographic modules, and REST API controllers to sync with our Cloudflare edge network, along with Enterprise-grade fleet deployment logic (MDM). Because of this deep backend orchestration and our commercial roadmap, the core client remains closed-source. That being said, because I know firsthand how painful local deployment is for independent draftsmen, we specifically carved out the BASE Mode (100% offline, air-gapped) and the FREE Tier (unlimited VCID sharing protocol) to be permanently free for the community. We wanted to make sure everyone could enjoy modern package management without paying a dime. It’s always a pleasure geeking out over deployment architectures with veterans. Thanks again for the great discussion! Quote
BIGAL Posted 4 hours ago Posted 4 hours ago (edited) I am still confused, yes I have around 150 lisps behind 3 pop menu's, and the idea of being simply able to find them I understand, but from a dumb user perspective how do I know how to call up a Lisp program, despite numerous post I still don't see how to call the lisps. There is no way where I worked in a team environment they would know the name of a lisp or a command that ran it. They would just walk away. @VicoWang Maybe show your CAD setup. Edited 4 hours ago by BIGAL 1 Quote
VicoWang Posted 3 hours ago Author Posted 3 hours ago (edited) @BIGAL Actually, regarding what the deployed CAD interface looks like: @Paul Li recently shared some of his custom tool suites in our community thread, and I posted a few test screenshots there demonstrating the exact setup—his custom .CUIX ribbons, floating toolbars, and slide libraries seamlessly mounted. You can see the setup screenshots here: To clarify our design philosophy regarding "how an end-user calls up a command": we completely agree that no one can or should memorize 150 commands. We view execution as two complementary workflows: High-Frequency Tools (The Keyboard Route): A draftsman typically relies on keyboard shortcuts for the ~20 tools they use every few minutes. Traditionally, changing the shortcut of a third-party LISP meant opening someone else's source code to alter defun c:... or writing your own wrapper functions. VedaCAD provides built-in custom alias management, allowing users to map and resolve shortcuts for their favorite routines directly from the manager without writing a single line of wrapper code. Visual & Specialized Tools (The Click Route): For the remaining 130 tools, visual access is mandatory. Whether a CAD Manager prefers deploying traditional .CUIX Ribbons / Toolbars, custom POP Menus (like your impressive setup!), or interactive Radial Menus (like the OmniWheel plugin I shared earlier), VedaCAD silently mounts and supports them all natively. The classic pull-down menus you showed in your screenshot are fully supported in our .CUIX pipeline. When a CAD Manager deploys a custom menu via VedaCAD, the end-user doesn't need to know the command names—they simply click your menu items or ribbon icons on the screen, exactly as they do in your office today. VedaCAD is not here to force a specific interface style; it is simply the underlying delivery infrastructure to carry whatever workflow the CAD Manager chooses to design. Since Paul's tool suites are live on the platform, the easiest way to see how this works is to test it firsthand. You are very welcome to grab a free account at app.vedacad.com, type VC, click 'Install via VCID', and try pulling one of his suites (e.g., B-NN9XC for his DDCalc suite). You can see how his visual ribbon, calculator, and tools wire up in your own workspace! Edited 3 hours ago by VicoWang Quote
Paul Li Posted 2 hours ago Posted 2 hours ago @BIGAL I just want to add more detail to @VicoWang explanation. To begin with, I would like to point out that I have over 11 apps all written in AutoLISP & DCL. When installed successfully the added commands from a typical app are presented with the loading of a partial menu which adds a panel under the Add-ins section of the Ribbon along with Toolbar so the end user knows exactly where to go to access the added commands. Prior to VedaCAD, these apps are all marketed on the Autodesk app store which is now called Design and Make Marketplace. Autodesk has a set a fairly vigorous review standards that must be met in order for a third party app to qualify in their app store. In additional, as a developer, you would have to submit everything to them to generate the msi setup file for user download and installation. This submittal for review process can take a number of weeks to approve before your app can go live on their app store. But then enters VedaCAD. I now can use the VC vlx app to create my own installation bundle without a need to submit my files to another company to review for approval. There's also no need for an msi setup file but instead all that is needed is the VC ID code that references that bundle on the VedaCAD server for complete installation. After the end user loads the VC .vlx app, all that is required is to import that VC ID code and my app is now installed exactly like it is using msi setup file. But the difference with VedaCAD is that the end user must now always load the VC.vlx file in order to have access to the added app. Hope this clarifies a bit more as to what VedaCAD does for you. SCLCLNG.LSP 1 Quote
aridzv Posted 53 minutes ago Posted 53 minutes ago @BIGAL About the pop menus: Interesting, I'll have a look. One thing I left out from my last comment is that I add most of my lisps to the ribbon as buttons so I don't need to remember or type the command. @VicoWang I don't use the excel file to run anything, It is just a table to keep track of my lisps. About me using bricscad and can't use .vlx: There are also .brx files In some forums that I avoid. I'll be a little more blunt: I will use compiled file from a known trusted vendor. This is not the case here. In public forums I'll stay with open source, Both for the reason I've mentioned earlier and the one above here. Quote
VicoWang Posted 40 minutes ago Author Posted 40 minutes ago @aridzv Completely fair point—trust isn't given on day one, it has to be earned over time. I respect your stance, and thank you for being candid. Quote
